> Martin wrote:
> > is it really needed in trunk in regards we are
> planning to use Python for all scripts?
Hamish:
> AFAIK it is needed whenever non-.exe or .bat named modules will be
> run using simply their command name.
Glynn:
It should only be needed for Tcl/Tk (exec and "open |..."), which has
its own hacks for .exe and .bat (maybe .com and/or .cmd? I'm not
sure).
Everything other than Tcl/Tk falls into one of two cases: either you
always have to provide the extension (even for .exe or .bat), or it
uses PATHEXT and the registry settings (related to ftype/assoc).
AFAICT for non-C modules in g7 Script.make runs the "$(BIN)/%.bat:"
Makefile rule (in ScriptRules.make) which creates .bat file wrapper.
But the helper scripts in $(TOPDIR)/gui/scripts/->$GISBASE/etc/gui/scripts/
do not use Script.make but still need that step.
BTW, we need to add .py to PATHEXT; we don't appear to be
doing this at present.
Index: lib/init/init.bat
--- lib/init/init.bat (revision 37138)
+++ lib/init/init.bat (working copy)
@@ -102,6 +102,7 @@
:wxpython
set PYTHONPATH=%PYTHONPATH%;%WINGISBASE%\etc\python;%WINGISBASE%\etc\wxpython
+set PATHEXT=%PATHEXT%;.PY
python "%GISBASE%/etc/wxpython/gis_set.py"
if %errorlevel% == 2 goto exitinit
for gr7 is it needed for all gui/tui modes I guess, not just wxGUI.
hmph, the above doesn't seem to stick.
On linux at least the .py is removed from the script name and the module
gets installed without extension in $GISBASE/scripts/
I'm note sure what happens with the g7 WinGRASS build.
Hamish
Hamish:
Glynn:
> sure).
Nothing should need the .bat wrapper once Tcl/Tk is dropped.
@@ -102,6 +102,7 @@
:wxpython
PATHEXT gets reverted?
It gets installed without the .py suffix, which won't work. I'll
commit a fix once it's tested.
