[GRASS-dev] Re: [GRASS-SVN] r40881 - in grass/trunk: gui/wxpython/nviz gui/wxpython/vdigit lib/gis visualization/wximgview
On Tue, Feb 9, 2010 at 3:28 AM, <svn_grass@osgeo.org> wrote:
Author: glynn
Date: 2010-02-08 21:28:10 -0500 (Mon, 08 Feb 2010)
New Revision: 40881
Modified:
grass/trunk/gui/wxpython/nviz/Makefile
grass/trunk/gui/wxpython/nviz/setup.py
grass/trunk/gui/wxpython/vdigit/Makefile
grass/trunk/gui/wxpython/vdigit/setup.py
grass/trunk/lib/gis/popen.c
grass/trunk/visualization/wximgview/main.cc
Log:
Windows fixes
Do these changes render the digitizer to be usable now?
A backport candidate?
> Author: glynn
> New Revision: 40881
> Modified:
> Log:
> Windows fixes
No. MinGW's gcc crashes when trying to link C++ programs. The above
changes simply mean that the modules get to the crash-on-link stage
rather than failing earlier with compile errors.
Only popen.c, but I have another change pending for that (G_pager()
still doesn't work, although I'm unclear on the reason).
On Wed, Feb 10, 2010 at 12:20 AM, Glynn Clements
> Author: glynn
> New Revision: 40881
> Modified:
> Log:
> Windows fixes
I am unsure about the popen.c backport since the 6.5 version
differs significantly from trunk. (same with the recent spaw.c
fixes).
>> > Log:
>> > Windows fixes
fixes).
Right; the popen.c replacement hasn't been back-ported (and probably
shouldn't be), so there's no point in back-porting fixes to it.
FWIW, popen.c should now be entirely unused in 6.5, and may as well be
removed. I replaced all occurrences of G_popen() with popen() in
r40834, and G_pclose() with pclose() in r40921, as G_popen() doesn't
work at all on Windows. These should be back-ported to 6.4 after
testing.
On Thu, Feb 11, 2010 at 2:16 AM, Glynn Clements
fixes).
I have done so to reduce the (file) noise.
These should be back-ported to 6.4 after testing.
-> still TODO.
Glynn:
> and may as well be removed.
Markus:
mmmph, we have no idea what functions people depend on in their
personal modules. We don't guarantee API compatibility, but
still it is not very nice to dump long serving functions in the
final part of a version's life ...
Hamish
On Thu, Feb 11, 2010 at 12:10 PM, Hamish <hamish_b@yahoo.com> wrote:
Glynn:
Markus:
Could G_popen() be made a wrapper to popen()?
(if it doesn't work on Windows, it is useful only to a fraction of
operating systems).
I have searched around in GDAL and QGIS for the presence of G_popen()
but did not find anything (except for complaints of non-portability). Checked
also koders.com.
It could.
OTOH, anyone who was using it could just define macros, e.g.:
  CFLAGS='-DG_popen=popen -DG_pclose=pclose' ./configure ...
operating systems).
also koders.com.
G_popen() wasn't being used in GRASS outside of lib/gis. Everything
else used popen().
