[GRASS-dev] Re: [GRASS-user] How can I find average/maximum raster values within a vector area?
On 02/08/07 06:59, David Finlayson wrote:
Forgot to CC grass list
On 8/1/07, David Finlayson <dfinlayson@usgs.gov> wrote:
I think you want the command r.statistics. You will need to convert
your administrative areas vector map into a raster map where each area
has a unique ID. Then run r.statistics on the pollution map using the
administrative areas raster as the cover. This tool builds a database
table with the min,max avg, etc statistics of pollution for each area
id.
How difficult would it be to create a module 'v.statistics' which would skip the step of converting the cover to raster ?
Moritz
George,
you could also use v.rast.stats to compute
pollution statistics for the administrative
areas. See [1] for more details.
Daniel.
[1] http://grass.itc.it/gdp/html_grass63/v.rast.stats.html
id.
Moritz
grassuser mailing list
grassuser@grass.itc.it
Many thanks to you both.
v.rast.stats looks perfect – it’s churning away as I write…
G
On 2 Aug 2007, at 09:52, Daniel McInerney wrote:
George,
Daniel.
id.
How difficult would it be to create a module ‘v.statistics’ which would skip the step of converting the cover to raster ?
Moritz
George MacKerron / 020 7870 7509
Another approach is to use a tool called Starspan. It works with any GDAL/OGR
datasource - including GRASS raster and vector files.
cheers,
Dylan
v.rast.stats looks perfect -- it's churning away as I write...
G
> George,
> Daniel.
>>>> each area
>>>> using the
>>>> database
>>>> area
>>>> id.
>> Moritz
>> _______________________________________________
