[GRASS-dev] Re: [GRASS-user] Is it possible to have two values for a raster. like say value1 , value2.
Pankaj wrote:
By the way, I have troubles with v.label module. I want to show both
the individual basin area and cumulative basin area on the map.
But, it's not working. (No <> map error.)
we need to see the full command line you tried, and the exact output from
it. (cut and paste is best)
did you use type=centroid to select areas?
(the centroid holds the area's attribute info)
Hamish
