[GRASS-dev] Re: [GRASS-user] Scripting i.ortho.photo
On Oct 16, 2008, at 8:09 AM, <grass-user-request@lists.osgeo.org> wrote:
Date: Thu, 16 Oct 2008 11:34:00 +0100
Subject: Re: [GRASS-user] Scripting i.ortho.photo
To: hamish_b@yahoo.com
Cc: GRASS user list <grass-user@lists.osgeo.org>
Message-ID: <48F71898.7000509@geodata.soton.ac.uk>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Hamish wrote:
right, if you look at the end of imagery/i.ortho.photo/menu/menu.c you
can see that each program runs as "$PGM group_name", except i.group
e.g., Andy try running: $GISBASE/etc/photo.rectify group_name
I am not sure, do all the photo.* modules require interaction or does
e.g. photo.rectify just start running once you call it?
Unfortunately photo.rectify is interactive still so I think there's
modification to the code required before it can be executed using
parameters alone.
I think photo.rectify is the key as all the other elements of the
i.ortho.photo sequence generate text files in the group directory to
store the parameters, and these could be created independently
Thanks very much for having a look though.
I'm pretty sure that if i.ortho.photo modules could be made to work like other GRASS modules in which the old interactive terminal interface was optional (i.e., they can take arguments and run without needing an interactive terminal), they could be scripted to work in the wxPython GUI. Most of the important interactive part is for rectification and we already have an interactive rectification system built in wxPython.
Michael
