[GRASS-dev] Re: [GRASS-user] V.extrude... confused
strange, I just tried out under Linux, works fine :-/ The vector map you
want to produce seems to be created anyway.
Maybe adding
G_percent(nelements, nelements, 1);
at the end of the module would help?
Jachym
Sampson, David píše v Út 12. 02. 2008 v 15:57 -0500:
Hey folks.
I want to make a 3d map of canada where each province is extruded base
don certain values. My provinces shape looked like it was being
hassled so I thought ok, keep it simple.
1. created a small shape in the digitizer
2. v.extrude the vector with a single element
3. used 30 as my height
v.extrude input=Ontario@sampson output=Ontario3D zshift=0 height=30
type=point,line,boundary,area layer=1
And it just hangs (output bellow).
The green bar does not complete.
I am using wingrass 6.3 cvs
And as I'm in windows the v.extrude process is still running. When I
kill the single process the whole GRASS session dies
This is the output:
0 areas built
0 isles built
Attaching islands:
Attaching centroids:
Topology was built.
Number of nodes : 19790
Number of primitives: 20075
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Building topology ...
Registering lines: 1000 2000 3000
4000 5000 6000 7000 8000
9000 10000 11000 12000 13000
14000 15000 16000 17000 18000
19000 20000
20075 primitives registered
Building areas:
Number of centroids : 0
Number of faces : 20017
Number of kernels : 58
Number of areas : 0
Number of isles : 0
grass-user mailing list
grass-user@lists.osgeo.org
you want to produce seems to be created anyway.
Maybe adding
Yes, G_percent() within the loop should usually be placed towards the
end of the for loop (so "finished 3%" instead of "started 3%"), and
also there should be an extra G_percent() after the loop has concluded
so you get to see the final 100%.
This doesn't affect the data in any way at all, just if you want to see
the 100% complete on the screen.
Hamish
      ____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
