On Oct 28, 2009, at 2:23 AM, grass-dev-request@lists.osgeo.org wrote:
Send grass-dev mailing list submissions to
grass-dev@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
grass-dev Info Page
or, via email, send a message with subject or body 'help' to
grass-dev-request@lists.osgeo.orgYou can reach the person managing the list at
grass-dev-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-dev digest..."Today's Topics:
1. gui_modules/colorrules.py bug and wishes (Markus Neteler)
Message: 1
Date: Wed, 28 Oct 2009 10:22:37 +0100
Subject: [GRASS-dev] gui_modules/colorrules.py bug and wishes
To: GRASS developers list <grass-dev@lists.osgeo.org>
Message-ID:
<86782b610910280222re95a0d5yb2f464499d3ab653@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"Hi,
trying "volors" (i.e., gui_modules/colorrules.py) I found small bug and
got a few ideas to improve this promising dialog.
Please see attached screenshot as I found it easier to indicate the
ideas there.Those which aren't easy to fix I'll submit later as tickets.
thanks
Hi Markus,
Interesting. The bug you've found is not the one you think you found ![]()
Both menu items "color rules" and "color tables" under vector->manage colors are bringing up the same color rules module from wxGUI. Instead, "color tables" should be bringing up the interface for the new v.colors GRASS module. I suspect it's just a typo in the menu string.
The vector color rules module does not do what you are assuming it does. That is, it does not automatically spread a color gradient between a max and min value. What it does is allow you to custom set colors to individual values or ranges of values, and store these colors in the GRASSRGB color column. The add column button may not be too hard to implement (automatically refreshing the column list may be the biggest headache). The other suggestions don't match this module. This module was written before v.colors and has different functionality.
The functions you thought were in the color rules wxGUI module are actualy in the v.colors GRASS module. The "color tables" menu option ought to call this module. It automatically sets max and min, but also allows the user to set custom max/min. It then lets you pick a color table and automatically assign the color gradients to the vector values.
I'll try to get this fixed when I get to my office today. Hopefully it's a simple typo.
Michael
