[GRASS-dev] Re: New qgis-grass win32 build
On 5/5/06, "Sören Gebbert" <soerengebbert@gmx.de> wrote:
Dear Radim,
good news! :slight_smile:
The lates version of the grass test suite (0.2.0.2) is working
(mostly complete) within the
MinGW environment of your latest Qgis-GRASS windows build.
Only my output generation script
has some problems, but this is related to me.
I made some screenshots of the xterm output of the test suite
for database, general, raster, raster3d and vector tests.
Nice and the result is not so bad. If you get the output working an HTML
report will be available?
Did you check the buffer output with validation-failure? Does it mean
that it works on Linux and fails on Windows? Is it the output realy wrong
or maybe just a difference in non significant decimal places?
What does it mean dependencies not fulfilled?
Radim
Great work Radim!!!
Best regards
Soeren
btw.:
Sorry for those ugly pictures,
but my windows-gimp is not in a recent version.
Echte DSL-Flatrate dauerhaft für 0,- Euro*!
"Feel free" mit GMX DSL! http://www.gmx.net/de/go/dsl
On Friday 05 May 2006 12:33, Radim Blazek wrote:
On 5/5/06, “Sören Gebbert” soerengebbert@gmx.de wrote:
Dear Radim,
Of course … but im still searching for the problem.
No, i only made the test runs. I did not verify the validation erros.
But the module v.buffer is kind of strange while generating output with many lines and
buffers greater then ~50m on different machines (linux).
I checkded this some time ago and figured out, that the output is equal, but
the order of the produced lines is different between the machines! I have no clue why… .
In this case the md5 checksum test will fail.
Even if i use valgrind for memchecks on the same machine, the v.buffer module shows this behavior:
You may want to look at the v.buffer test part of:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html/
The Normal precision difference between machines is catched, because the float
output is truncatd of 3 decimal places via v.out.ascii.
This is a new feature. The test suite is trying to figure out what dependences the grass installation has.
e.g.: if gdal, ogr, postgresql, mysql and stuff is linked against grass
Within the test scripts you can define this dependences.
The r.in.gdal and r.out.gdal modules depend on gdal,
so i made the entry NEED_GDAL=“yes” in the test scripts.
Example script:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html//r.out.gdal-test.sh.html
Bevor the test is executed, the test suite trys to figure out if gdal is installed by testing if r.in.gdal was build … very simple,
but i have no other way to figure this out (If the build information is written to a txt file which will be available like the BULD file in $GISBASE/etc,
things would be much easier for me. )
If r.in.gdal is not found, the test suite guess that gdal is not installed and linked, so every test depending on gdal is not executed
and a warning message is printed to stdout.
These are the dependences the test suite figured out within windows:
BLAS no
CXX no
DWG no
FFMPEG no
FFTW no
FREETYPE no
GDAL no
GLW no
JPEG no
LAPACK no
LFS no
MOTIF no
MYSQL no
NLS no
ODBC no
OGR no
OPENGL no
PNG no
POSTGRESQL yes
PROJ.4 no
READLINE no
SQLITE yes
TCLTK no
TIFF no
X11 no
Some of them like BLAS, LAPACK, READLINE, LFS and FREETYPE are not checked, because id dont know how!
But the values can be changes in the GlobalSettings script:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html//GlobalSettings.html
Within the test scipts several dependences can be defined, you may want to look at the Template:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html//TestScriptTemplate.html
Best regards
Soeren
btw.:
Can i run those tests within Windows 98? So i can use vmware
and dont have to boot Windows XP. I have only one XP license.
Radim
Great work Radim!!!
Best regards
Soeren
btw.:
“Feel free” mit GMX DSL! http://www.gmx.net/de/go/dsl
lines and
clue why.... .
I was already thinking about v.diff, in any case it would be interesting
to find why the order can differ.
so i made the entry NEED_GDAL="yes" in the test scripts.
But it obviously fails because r.in/out.gdal should work.
Cannot you simply try to run r.in.gdal --help?
I think that XP is better, I dont believe many people are using 9x.
Radim
i fixed some bugs in the test suite. (im sure there are still a lot of
them.....)
Now it runs without problems within the MinGW32 environment on my machine.
The test
suite:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/GRASS_Testsuite-0.2.0.3.tar.bz2
The html output i have generated:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html/MinGW32/
A screenshot of the test suite running database, general and raster tests
within
MinGW32:
http://www-pool.math.tu-berlin.de/~soeren/grass/modules/screenshots/QgisGrassMingw-TestSuite-Result-db-general-raster.png
Happy testing :wink:
Any suggestions and bugreports are welcome!
Soeren
did you find if v.buffer realy fails or only line order differ?
It should be possible with sed/awk to modify ascii output
to have each element on single line and then sort it.
Then the sum should not depend on line order.
Radim
them.....)
The test
suite:
within
MinGW32:
Soeren
