[GRASS-dev] [release] planning GRASS 7.4.2
GRASS 7.4.1 has been released 12 Jun 2018 [1]. I would suggest to
start preparing point version 7.4.2 as soon as possible:
Proposal of release: 14 Sep
Soft freeze of release branch: 21 Sep
RC1: 05 Oct
RC2: 19 Oct
Final release: 26 Oct 2018
It's 4 months after 7.4.1.
What do you think? Since it's point version we could shorten "Soft
freeze of release branch" and release RC1 earlier.
Ma
[1] https://trac.osgeo.org/grass/wiki/Release/7.4.1-News
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Thu, Sep 13, 2018 at 3:39 PM Martin Landa <landa.martin@gmail.com> wrote:
RC1: 05 Oct
RC2: 19 Oct
Sounds good. I think that release branch is in pretty good shape, i.e.
I don't expect any backports any more.
Martin Landa
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
pá 14. 9. 2018 v 17:33 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
> RC1: 05 Oct
> RC2: 19 Oct
great, I took liberty to shorten soft freeze period [1]. Ma
[1] https://trac.osgeo.org/grass/milestone/7.4.2
Martin Landa
pá 14. 9. 2018 v 18:08 odesílatel Martin Landa <landa.martin@gmail.com> napsal:
> > RC1: 05 Oct
BTW, there is blocker [1]. Is there anyone who is planning to work on
this issue? Otherwise we would need to postpone release or decrease
ticket priority.
Any opinion? Ma
[1] https://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&priority=blocker&priority=critical&milestone=7.4.2&milestone=7.4.1&milestone=7.4.0&group=type&order=priority
Martin Landa
I will look at it, this happens only with wxPython4, it should be easy to fix.
On Tue, Sep 25, 2018 at 2:44 PM Martin Landa <landa.martin@gmail.com> wrote:
RC1: 05 Oct
ticket priority.
Any opinion? Ma
Martin Landa
út 25. 9. 2018 v 20:52 odesílatel Anna Petrášová <kratochanna@gmail.com> napsal:
thanks. Ma
Martin Landa
FYI - time to package 7.4.2RC2:
Time schedule:
- Proposal of release: 14 Sep [DONE]
- Soft freeze of release branch: 21 Sep [DONE]
- RC1: 28 Sep [DONE]
- RC2: 12 Oct <== I'll do that today!
- Final release: 19 Oct
Best
On Sun, Oct 14, 2018 at 12:42 PM Markus Neteler <neteler@osgeo.org> wrote:
Time schedule:
done:
release_20181014_grass_7_4_2RC2
To be improved:
https://trac.osgeo.org/grass/wiki/Release/7.4.2-News
Please check remaining bugs at:
https://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&group=status&milestone=7.4.2
ne 14. 10. 2018 v 17:27 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
done:
wingrass standalone and osgeo4w (expr area) uploaded for testing. Ma
Martin Landa
po 15. 10. 2018 v 0:12 odesílatel Martin Landa <landa.martin@gmail.com> napsal:
> done:
Ubuntu packages from UbuntuGIS Expr PPA [1] are also available for testing. Ma
[1] https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-experimental/+packages?field.name_filter=grass&field.status_filter=published&field.series_filter=
Martin Landa
Hi Markus, all
ne 14. 10. 2018 v 12:42 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
if no objection I would suggest to trigger tagging final release.
Thanks, Martin
Martin Landa
On Sat, Oct 20, 2018 at 9:24 PM Martin Landa <landa.martin@gmail.com> wrote:
Hi Markus, all
... working on it right now.
po 22. 10. 2018 v 22:00 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
wingrass packages (osgeo4w and standalone) uploaded. UbuntuGIS
packages will be packaged in the next days. Ma
Martin Landa
Dear Jurgen,
to avoid broken GRASS plugin in OSGeo4W for longer time I just wanted
to ask you if you are rebuilding qgis osgeo4w packages automatically
when new GRASS version is published? Should I inform you about new
GRASS version personally or you are following also GRASS ML? For
better cooperation in the future: I could put new grass version to
expr (test) at first, wait for new qgis build and then publish also
grass. What do you think, Ma
---------- Forwarded message ---------
Date: st 24. 10. 2018 v 9:53
Subject: Re: [GRASS-dev] [release] planning GRASS 7.4.2
To: Markus Neteler <neteler@osgeo.org>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
Martin Landa
Martin Landa
st 24. 10. 2018 v 9:53 odesílatel Martin Landa <landa.martin@gmail.com> napsal:
UbuntuGIS packages were finally uploaded to Unstable PPA [1].
Meanwhile I have updated QGIS version to 2.18.24 [2].
Ma
[1] https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable/+packages?field.name_filter=grass&field.status_filter=published&field.series_filter=
[2] https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable/+packages?field.name_filter=qgis&field.status_filter=published&field.series_filter=
Martin Landa
st 28. 11. 2018 v 14:28 odesílatel Jürgen E. Fischer <jef@norbit.de> napsal:
I updated the processing provider to automatically pick the latest GRASS
directory - before it was configured in the user profile and never updated at
all and processing would look broken after a GRASS update - that should be fine
now.
thanks for info.
But the GRASS plugin will be broken between the GRASS update and the next QGIS
point release. As QGIS will only be built automatically on QGIS releases.
This is very unfortunate (cc'ed to grass-dev). We have two options:
1) update GRASS package (as current) to OSGeo4W when released
+ a new GRASS version available in OSGeo4W when released
- we don't care about broken QGIS GRASS plugin
2) publish GRASS release in OSGeo4W as test package and change to
current when new QGIS point release
+ QGIS GRASS plugin will be not broken
- new GRASS version available when QGIS point release published
+/- there is still possibility to install new GRASS version from Expr area
Any comments? I would vote for 2). In this case Juergen could you
change test -> curr in GRASS setup.hint when pushing new QGIS point
release to OSGeo4W or let me/us know to do it? Would be nice to
collaborate more closely to avoid broken QGIS-GRASS interfaces.
Thanks, Ma
Martin Landa
Hi Martin,
Last time the GRASS release was shortly before the QGIS release and fell in
smoothly - this time it's shortly after. The QGIS release echedule is set long
upfront.
Not putting the patch level into the GRASS library names (and keeping an eye on
the ABI - but I suppose the library interfaces only change rarely anyway - and
if so not on point releases), would be a third option. IIRC there's also still
a safety check to remove in the GRASS libs to make this possible. Then GRASS
point releases wouldn't need a QGIS rebuild at all.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
(attachments)
Pflichtangaben (206 Bytes)
On 28/11/18 14:54, Jürgen E. Fischer wrote:
Hi Martin,
upfront.
This sounds like the way to go for me. AFAIK, there shouldn't be ABI changes between point releases.
Moritz
st 28. 11. 2018 v 15:08 odesílatel Moritz Lennert
<mlennert@club.worldonline.be> napsal:
I changed trunk to produce also unversioned libs similarly as on
non-mingw platforms [0]. On Windows it's simply copy of versioned
libs. Is it acceptable solution? If so I will do backport to g76 a g74
branches ASAP. BTW, GRASS 7.4.4 is planned to be released in next
days, see [1].
Martin
[0] https://trac.osgeo.org/grass/ticket/3718
[1] https://lists.osgeo.org/pipermail/grass-dev/2018-December/090810.html
Martin Landa
