[GRASS-dev] [release planning] GRASS GIS 7.2.2
GRASS 7.2.1 has been released on 3rd May 2017, so time to plan the
next release, i.e. 7.2.2. Currently 7.2.2 release is planned in July
[1]. It would mean, following RFC4 [2] using [3]:
2017-07-05 - soft freeze (only bugfixes)
2017-08-04 - hard freeze + RC1
2017-08-14 - RC2
2017-08-29 - final
It would be nice also to solve waiting backports [4] till 2017-07-05
or also at the FOSS4G-E code sprint.
Opinions?
[1] https://trac.osgeo.org/grass/milestone/7.2.2
[2] https://trac.osgeo.org/grass/wiki/RFC/4_ReleaseProcedure
[3] derive RFC4 dates tool :slight_smile:
#!/bin/sh
for d in 0 30 40 55 ; do
  delay=7 # between this first announcement and day X
  d=`expr $d + $delay`
  date -d "now +$d days" +"%Y-%m-%d"
done
[4] https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.2.2tobebackported
2017-06-28 23:02 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
2017-08-14 - RC2
2017-08-29 - final
Opinions?
make sense to me. Would be nice to release RC1 at FOSS4G-E, but it
would be probably too early regarding to soft freeze period.
#!/bin/sh
done
What about putting it to grass_addons/tools ?
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Sun, Jul 9, 2017 at 12:50 PM, Martin Landa <landa.martin@gmail.com> wrote:
2017-08-14 - RC2
2017-08-29 - final
Opinions?
We just need to start :slight_smile:
#!/bin/sh
done
Sure: r71252.
2017-07-09 15:08 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Sure: r71252.
thanks, cool :slight_smile: Ma
Martin Landa
2017-08-14 - RC2
2017-08-29 - final
kind reminder, we are close to hard freeze, only bugfixes are allowed
in relbr72. Martin
Martin Landa
On 03/08/17 09:58, Martin Landa wrote:
2017-08-14 - RC2
2017-08-29 - final
in relbr72. Martin
Could you have a look at #3380 ? Can we backport ?
Moritz
2017-08-03 9:58 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
2017-08-14 - RC2
2017-08-29 - final
in relbr72. Martin
so far no blocker [1], we can go ahead. Ma
[1] https://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&priority=blocker&priority=critical&milestone=7.2.2&group=type&order=priority
Martin Landa
Hi Moritz,
2017-08-03 10:02 GMT+02:00 Moritz Lennert <mlennert@club.worldonline.be>:
done in r71322. Martin
Martin Landa
what about these fixes here done by mmetz?
r71253 dbmi_base lib: add missing arg type
r71191 lidarlib: free structs
They are not backport yet in case they should be.
markusN
2017-08-04 11:37 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
I think so, done in r71323-4. Ma
Martin Landa
As can be seen from [1], there is confusion about v.in.ogr syntax for importing PostGIS layers. This was modified in May (r71093/r71096) to correspond to ogr syntax. The man page still has other info, however.
IIUC, in the current (trunk and release72) version, this is enough to import a layer:
v.in.ogr input="PG:host=localhost dbname=postgis user=postgres" layer=polymap \
output=polygons type=boundary,centroid
and with schema:
v.in.ogr input="PG:host=localhost dbname=postgis user=postgres" layer=schema.polymap \
I'm not sure if any of the info in the "Default connection settings as datasource (PostgreSQL only)" section of the man page is still valid. If not, I suggest to erase the entire section and add an example with a schema into the "PostGIS tables" section.
Martin, any comments ?
Moritz
[1] https://lists.osgeo.org/pipermail/grass-user/2017-August/076804.html
Hi devs,
On Wed, Jun 28, 2017 at 11:02 PM, Markus Neteler <neteler@osgeo.org> wrote:
... tagging RC1 now (the Windows packages are back).
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
On Thu, Aug 10, 2017 at 10:39 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi devs,
RC1 is available:
https://trac.osgeo.org/grass/wiki/Release/7.2.2-News#ReleaseCandidate1RC1
Binaries and announcements work in progress...
2017-08-11 11:04 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
RC1 is available:
Windows binaries are available for testing [1], also OSGeo4W package
uploaded (you need to mark `Exp` box).
Ma
[1] https://grass.osgeo.org/grass72/binary/mswindows/native/
Martin Landa
2017-08-11 11:26 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
bad news, I tested standalone binaries on fresh Windows 8.1 VM. GUI is
failing with Error 126, g.region from CLI says, missing
api-ms-crt-runtime-l1-1-0.dll. I will try to fix it ASAP and produce
new binaries. Ma
Martin Landa
2017-08-11 11:45 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
new binaries. Ma
can someone tested on Windows 8.1 and different versions? Ma
Martin Landa
On Fri, Aug 11, 2017 at 5:48 AM, Martin Landa <landa.martin@gmail.com> wrote:
new binaries. Ma
I tested 64bit version on windows 10 and it works for me, but lidar
tools are missing.
Martin Landa
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
2017-08-11 15:59 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
tools are missing.
you are right, I have accidentally disabled las support also on 64bit
platform. Unfortunately building server is not accessible since
15:00CET (at least for two days) due to network reconfiguration at
CTU. Should be fixed in trunk (r71392). I will do backport later when
first G73 64bit build will be published (probably on Monday). Ma
Martin Landa
2017-08-11 17:05 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
tools are missing.
well, it broke [1] 64bit even few days ago it worked [2]. No changes
in buliding envirnment since then. Windows mystery, I am lost, any
idea?
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin/r.in.lidar.exe:
error while loading shared libraries: libgrass_raster.7.3.svn.dll:
cannot open shared object file: No such file or directory
Ma
[1] https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71395-321/package.log
[2] https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71337-316/package.log
Martin Landa
2017-08-14 11:54 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
of course the library exists
$ file /c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/lib/libgrass_raster.7.3.svn.dll
/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/lib/libgrass_raster.7.3.svn.dll:
PE32+ executable (DLL) (console) x86-64, for MS Windows
and
is in the path. Other raster modules do not fail. Only those with LAS
support. Ma
Martin Landa
