[GRASS-dev] Resolved - Error in GRASS GIS 7.0 database
Hi Nikos,
Thanks for the reply.
When I run g.region and I give any raster name as an option, I still got the same error. I didn’t try changing the t-b resolution, though.
But after further looking around I found out that the file “WIND” inside my mapset was being changed every time, whenever a file was being edited in the database.
When I looked at it I found two entries for t-b resolution, I thought it’s supposed to be locked only for edit by one process at a time? After removing the duplicate entry the error when away.
Erick
On Tue, Nov 25, 2014 at 6:54 AM, Erick Opiyo <osgis.dev@gmail.com> wrote:
But after further looking around I found out that the file "WIND" inside my
database.
Is it possible that you are somehow affected by
https://trac.osgeo.org/grass/ticket/2230
? (... and how old is your installation - see "g.version -g")
version=7.0.0svn
date=2014
revision=61465
build_date=2014-07-31
build_platform=x86_64-unknown-linux-gnu
Should I upgrade?
On Nov 25, 2014 2:27 PM, “Erick Opiyo” <osgis.dev@gmail.com> wrote:
version=7.0.0svn
date=2014
revision=61465
Should I upgrade?
Yes please.
After the upgrade to grass 7.1.svn(2014)-r62856
Most of my initial python scripts can’t run, I get the error below.
File “phenology/cloud_filter/grass_modis_filter_MODIS.py”, line 13, in
l = dict.keys(g.parse_command(“g.mlist”,type=“rast”))
File “/usr/local/grass-7.1.svn/etc/python/grass/script/core.py”, line 465, in parse_command
res = read_command(*args, **kwargs)
File “/usr/local/grass-7.1.svn/etc/python/grass/script/core.py”, line 422, in read_command
process = pipe_command(*args, **kwargs)
File “/usr/local/grass-7.1.svn/etc/python/grass/script/core.py”, line 397, in pipe_command
return start_command(*args, **kwargs)
File “/usr/local/grass-7.1.svn/etc/python/grass/script/core.py”, line 358, in start_command
return Popen(args, **popts)
File “/usr/local/grass-7.1.svn/etc/python/grass/script/core.py”, line 62, in init
subprocess.Popen.init(self, args, **kwargs)
File “/usr/lib/python2.7/subprocess.py”, line 679, in init
errread, errwrite)
File “/usr/lib/python2.7/subprocess.py”, line 1249, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
I guess, the command g.parse_command is no longer valid in grass 7.1. I have see in some forums, reference to a new grass python module pygrass.
I assume this is now the default interface of python to grass. I will go through it and see if I can refactor my codes to use pygrass.
Thanks
I would consider to stick to the 7.0 release branch (I intended an
update of your existing 7.0 installation).
See
http://trac.osgeo.org/grass/wiki/DownloadSource#GRASS7.0
To extract the current 7.0.0 release branch version (upcoming stable),
which continuously receives bugfixes, use the command:
  svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_7_0
grass70_release
  #Subsequent updates:
  svn up
Most of my initial python scripts can't run, I get the error below.
g.mlist no longer exists, it has been renamed to g.list. Same for
g.mremove -> g.remove.
  File "phenology/cloud_filter/grass_modis_filter_MODIS.py", line 13, in
<module>
    l = dict.keys(g.parse_command("g.mlist",type="rast"))
  File "/usr/local/grass-7.1.svn/etc/python/grass/script/core.py", line 465,
in parse_command
  File "/usr/local/grass-7.1.svn/etc/python/grass/script/core.py", line 422,
in read_command
  File "/usr/local/grass-7.1.svn/etc/python/grass/script/core.py", line 397,
in pipe_command
  File "/usr/local/grass-7.1.svn/etc/python/grass/script/core.py", line 358,
in start_command
  File "/usr/local/grass-7.1.svn/etc/python/grass/script/core.py", line 62,
in __init__
    subprocess.Popen.__init__(self, args, **kwargs)
  File "/usr/lib/python2.7/subprocess.py", line 679, in __init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1249, in _execute_child
No, it is g.mlist that causes the problem. This is true for GRASS 7.0 and 7.1
Markus M
I have
Thanks
grass-dev mailing list
grass-dev@lists.osgeo.org
I have replaced g.mlist with g.list.
And now I have two versions of grass 7.0-r62941 and 7.1-r62932
But, now I get another wired error, shown below: For both 7.0 and 7.1
7.0
ERROR: output map <MOD13Q1.h16v05.2000081.EVI.Filtered.tiff> exists
File “phenology/cloud_filter/grass_modis_filter_MODIS.py”, line 72, in
R3,R2,R4,R1,R5,E3), overwrite=False)
File “/usr/local/grass-7.0.0svn/etc/python/grass/script/core.py”, line 465, in parse_command
File “/usr/local/grass-7.0.0svn/etc/python/grass/script/core.py”, line 425, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File “/usr/local/grass-7.0.0svn/etc/python/grass/script/core.py”, line 308, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None [‘r.mapcalc’, ‘expression=…some long expression…)’] ended with error
Process ended with non-zero return code 1. See errors in the (error) output.
Note: The line 72 in the file grass_modis_filter_MODIS.py starts with g.parse_command(“r.mapcalc”, expression=…
7.1
File “/usr/local/grass-7.1.svn/etc/python/grass/script/core.py”, line 425, in read_command
File “/usr/local/grass-7.1.svn/etc/python/grass/script/core.py”, line 308, in handle_errors
Thanks
Erick
On Tue, Nov 25, 2014 at 3:59 PM, Markus Metz
For an overview, see
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Renamedmodules
7.0
  File "phenology/cloud_filter/grass_modis_filter_MODIS.py", line 72, in
<module>
  File "/usr/local/grass-7.0.0svn/etc/python/grass/script/core.py", line
grass.exceptions.CalledModuleError: Module run None ['r.mapcalc',
'expression=.......some long expression.....)'] ended with error
g.parse_command("r.mapcalc", expression=.....
7.1
<module>
in parse_command
  File "/usr/local/grass-7.1.svn/etc/python/grass/script/core.py", line 425,
in read_command
  File "/usr/local/grass-7.1.svn/etc/python/grass/script/core.py", line 308,
in handle_errors
can I suggest you to use the python interface to r.mapcalc [0]
http://grass.osgeo.org/grass71/manuals/libpython/script.html#script.raster.mapcalc
parse_command it should be used only to read the output of module
using the '-g' flag for shell style output, not to run modules that
are doing analysis
Thanks
Erick
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
2014-11-25 16:36 GMT+01:00 Erick Opiyo <osgis.dev@gmail.com>:
<module>
overwrite=True
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
@Luca,
I will try the python interface out.
@Martin,
If I set overwrite=True, then it would make my script overwrite an already processed images, I’m executing the script a numbers of times to match my machine CPU load average and the overwrite check, makes sure that a subsequent process skips an already processes image from a previously executed process.
I tried python multiprocess module, but it was slower than executing one process, so to fasten the process, since I’m processing almost 2 TB MODIS images, I have opted to execute the script a number of times.
Erick
2014-11-25 17:06 GMT+01:00 Erick Opiyo <osgis.dev@gmail.com>:
processed images, I'm executing the script a numbers of times to match my
executed process.
well, but it's related to the error
Martin
Martin Landa
On Tue, Nov 25, 2014 at 11:25 AM, Martin Landa <landa.martin@gmail.com>
wrote:
already
> executed process.
if you want to ignore it, you can catch the exception:
from grass.exceptions import CalledModuleError
try:
    # call mapcalc
except CalledModuleError:
    pass
Anna
Martin
Martin Landa
