[GRASS-dev] Setting up the Github backport application
we activated the backport bot also for GRASS GIS in the Gihub OSGeo
organization.
As far as I understood from Even's email
https://lists.osgeo.org/pipermail/gdal-dev/2019-March/049928.html
the system is fairly straight forward (activate bot, define a new
"backport <branch>" label, set it to a PR).
So I tested it with a trivial README.md change but it didn't
cherry-pick but tried to backport the entire master to release_branch
differences!
Any ideas what's wrong?
thanks
On dimanche 26 mai 2019 16:31:04 CEST Markus Neteler wrote:
organization.
differences!
Where did you try ? I can't see any "backport XXXX" label in
https://github.com/OSGeo/grass/labels nor a pull request with the label.
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
On Sun, May 26, 2019 at 5:24 PM Even Rouault <even.rouault@spatialys.com> wrote:
> Hi,
> organization.
> differences!
Since it did potential damage, I have already removed the labels.
This was the PR I wanted to auto-backport:
https://lists.osgeo.org/pipermail/grass-commit/2019-May/045413.html
and see here (at end of page) the many "backporting[bot] " refs:
https://lists.osgeo.org/pipermail/grass-commit/2019-May/date.html
thanks
