Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
On Sat, Jan 7, 2017 at 5:00 PM, Travis CI <builds@travis-ci.org> wrote:
*GRASS-GIS / grass-ci <https://travis-ci.org/GRASS-GIS/grass-ci>\* (master
<https://github.com/GRASS-GIS/grass-ci/tree/master>\)
Build #1837 is still failing.
<https://travis-ci.org/GRASS-GIS/grass-ci/builds/189871967>
12 minutes and 48 seconds
*Anna Petrášová* 542a054
<https://github.com/GRASS-GIS/grass-ci/commit/542a054d805b7c5243f7672923f25b9075e667fa> Changeset
<https://github.com/GRASS-GIS/grass-ci/compare/2f8413b50c12...542a054d805b>
v.surf.rst: fix compilation for clang
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70294
15284696-431f-4ddb-bdfa-cd5b030d7da7
*Want to know about upcoming build environment updates?*
<http://eepurl.com/9OCsP>\.
Documentation <https://docs.travis-ci.com> about Travis CI
Need help? Mail support <support@travis-ci.com>!
Choose who receives these build notification emails in your configuration
file <https://docs.travis-ci.com/user/notifications>\.
*Would you like to test your private code?*
<https://travis-ci.com?utm_source=build_email_footer&utm_campaign=travis-ci.org&utm_medium=email>
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi, it's failing on Mac only, but I don't see a log, so I can't fix it. I
can look at it on Monday if that's ok.
Anna
On Sat, Jan 7, 2017 at 5:24 PM, Anna Petrášová <kratochanna@gmail.com>
Why is Mac build using brew? I would expect it to use the source code from
the repo directly.
