[GRASS-dev] still problems with overwrite in scripts
I thought from reading past mail posts that -o and --o and --overwrite all set the overwrite flag.
I test for overwrite with grass.overwrite()
But how do I include a check box for the overwrite flag in the GUI specs (for g.parser)?
Putting in an “o” flag does not seem to set the overwrite flag (at least in GRASS 7).
Putting in a “-o” (for creating --o) shows “-” in the interface. Not good.
So how to do this in a python script? I’ve looked at several other python scripts in the main GRASS 7 distribution and can’t find a script that deals with this issue. All seem to ignore setting an overwrite flag in the GUI.
Michael
C. Michael Barton
Visiting Scientist, Integrated Science Program
National Center for Atmospheric Research &
University Corporation for Atmospheric Research
303-497-2889 (voice)
Arizona State University
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
The last two do; the first one is just a normal flag.
Historically, modules used -o for overwrite, but that is deprecated in
favour of the --o/--overwrite option which is built into G_parser().
(for g.parser)?
If any of the options have a gisprompt setting which starts with
"new", the --help output will display the --o flag and the GUI will
have a checkbox to enable overwrite.
In 7.0, you can force the existence of the overwrite flag by adding
"#% overwrite: yes" to the module options, but this doesn't work in
6.x, partly because it isn't implemented in g.parser and partly
because the underlying logic in G_parser() is broken; see:
  https://trac.osgeo.org/grass/ticket/1658#comment:1
Thanks. I'll try one of these methods.
Michael
(for g.parser)?
  #1658 (g.rename, g.copy do not ask for --overwrite, they just do it) – GRASS GIS
_____________________
C. Michael Barton
University Consortium for Atmospheric Research
Hmmm. This should have worked. But...
The options (copied from another script) are written as...
#%option G_OPT_R_INPUT
#% key: ms3
#% description: Input raster map for red channel
#%end
So there is no way to add "new" unless I redo the options section. This way of doing the interface is new, but I thought that maybe it is the desired approach for Python now.
I added "#% overwrite: yes" by itself,
as...
#%option
#% overwrite: yes
#%end
and as another line in an existing option section
In all cases, it generated an error.
Suggestions?
Michael
(for g.parser)?
C. Michael Barton
going back to your original question, if you use --overwrite
with the master script, it should be set for everything called
by the master script as the GRASS_OVERWRITE enviro var will
be set by the parser. You can test to see if it is set with:
import os
    if "GRASS_OVERWRITE" in os.environ:
        print 'ow is ',os.environ["GRASS_OVERWRITE"]
    else:
        print 'os is not set.'
but if the intention is to have modules started within the
master script to respect it too, you shouldn't have to do anything
as it was already taken care of automatically via the exported
enviro var.
Hamish
2012/6/28 Michael Barton <michael.barton@asu.edu>:
#% key: ms3
#%end
but this is standard option for input not output! "new" refers to
`gisprompt`. Eg.
#% gisprompt: new,cell,raster
but is added automatically e.g. for G_OPT_R_OUTPUT.
as...
#%option
#% overwrite: yes
#%end
wrong, see my previous answer (just read it carefully)
#%module
#% overwrite: yes
#%end
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Thanks, but neither are relevant (or work) in my case. See below.
2012/6/26 Michael Barton <Michael.Barton@asu.edu>:
What is the test for the parser based overwrite flag?
as I told you the flag is added by parser automatically when there is
at least one option which is dedicated for output, eg. G_OPT_V_OUTPUT
or G_OPT_F_OUTPUT.
I don't want a pull down list of existing files. I just want a string option so that users can enter a prefix to create 3 output files.
So %# type: string.
Of course this does not automatically add the overwrite flag
Martin
Martin Landa <landa.martin gmail.com> * Studijní program Geodézie a kartografie – GeoWikiCZ
My question was about testing for the overwrite flag. But I did try this, as I mentioned in my post to Glynn and get an error wherever I put it. I tried in the string option for output prefix first, of course. But when that didn't work, I tried in the input and pull-down for sharpening algorithm too. No luck anywhere. If it only works in an option specified by G_OPT_R_OUTPUT and G_OPT_V_OUTPUT automatically generates and overwrite flag box without adding it, it seems kind of redundant. Shrug.
I wrote a workaround using an -o flag. But if there is some other way to do this, let me know.
It will help when the g.parser docs are updated from the current BASH centric examples to use G_OPT_R_OUTPUT, G_OPT_V_OUTPUT, and other such function that currently only show up in the C part of the programmer's manual.
Michael
Is there some special way to specify an overwrite flag in a script? Or is it
just:
overwrite flag should be added automatically by the parser when the
module produces any output. In really special cases you can force
adding overwrite flag by
#%module
#% overwrite: yes
#%end
Martin
On Jun 28, 2012, at 1:10 AM, Martin Landa wrote:
#% key: ms3
#%end
`gisprompt`. Eg.
as...
#%option
#% overwrite: yes
#%end
#%module
#% overwrite: yes
#%end
Martin
C. Michael Barton
The "overwrite" setting goes in the module section (along with
keywords), not the options/flags sections.
In C (this is from r.mapcalc):
    module = G_define_module();
    G_add_keyword(_("raster"));
    G_add_keyword(_("algebra"));
    module->description = _("Raster map calculator.");
    module->overwrite = 1;
In Python (there aren't any scripts which currently require this
feature, so this is contrived):
  #%module
  #% description: This is a script
  #% keywords: script
  #% overwrite: yes
  #%end
It only works in 7.0. In 6.x, g.parser won't recognise the overwrite
setting, and using it in C will force the overwrite setting on due to
bug #1658.
Thanks!!!
This is what I needed to know.
Michael
  #%module
  #% keywords: script
  #% overwrite: yes
  #%end
bug #1658.
C. Michael Barton
Works perfectly.
Michael
  #%module
  #% keywords: script
  #% overwrite: yes
  #%end
bug #1658.
C. Michael Barton
