[GRASS-dev] strange mapcalc result
On Jul 18, 2011, at 9:00 AM, grass-dev-request@lists.osgeo.org wrote:
Helena:
that r.mapcalc is now a normal module using G_parser() and so requires
special care with '=' (as described by Markus) should definitely be
mentioned in any changes from grass6 list. fwiw over the last year I've
slowly been going around updating all grass6 scripts and help examples
I've come across to add the spaces to make them forward compatible.
pthreads doesn't parse, it breaks up the processing into multiple threads
internally for a performance gain.
Hamish
On the Mac at least, it does not matter whether or not there are spaces around the "=".
For example...
GRASS 7.0.svn (spearfish60_test):~ > g.copy rast='elevation_dem,mapcalc_test'
Copy raster <elevation_dem@PERMANENT> to current mapset as <mapcalc_test>
this one has no spaces...
GRASS 7.0.svn (spearfish60_test):~ > r.mapcalc expression='mapcalc_test2=mapcalc_test+1'
100%
this one has spaces...
GRASS 7.0.svn (spearfish60_test):~ > r.mapcalc expression='mapcalc_test3 = mapcalc_test+1'
100%
both work and there is no difference between the results...
GRASS 7.0.svn (spearfish60_test):~ > r.mapcalc expression='mapcalc_diff=mapcalc_test2-mapcalc_test3'
100%
GRASS 7.0.svn (spearfish60_test):~ > r.info mapcalc_diff -r
min=0
max=0
MIchael
______________________________
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
    http://www.public.asu.edu/~cmbarton
