I tried to add to svn add-ons new module but I did it probably wrong.
In raster directory I created new dir:
svn add r.stream.del
svn ci -m "New module" r.stream.del
jarekj@jarekj-desktop:~/src/add-ons/raster$ svn ci -m "New module" r.stream.del
Sending r.stream.del/Makefile
Sending r.stream.del/description.html
Sending r.stream.del/global.h
Sending r.stream.del/io.c
Sending r.stream.del/main.c
in that moment all files from r.stream.del have been send to r.stream.basins (Why??? I was in raster directory when I added new subdirectory) and updated that directory. Now that directory is corrupted. So I have a problem...
revision version is 39503 after updating
BTW... I wrote r.stream.del module base on r.stream.basins code (i.e I copied r.stream.basin to r.stram.del and modified the code. It is the only relationship between that two modules.
Maybe not the most elegant way to do it, but works for me.
Maybe there was still some svn information in hidden files within r.stream.del, depending on how you created that directory (e.g. copying or renaming r.stream.basins to r.stream.del could cause such behaviour).
Markus M
you probably copied also metadata dictionary (.svn). It could be the
reason. The best way to fork a module is to use 'svn copy' otherwise
logs are broken.
logs are broken.
You can also do
However, this should only be done if it's *completely* new code. If
it's based upon existing code in any way, start with "svn copy", then
modify the copy,
Note: the meaning of "modify" doesn't include overwriting a file with
something based upon an older version. It's imperative that subversion
knows which revision the code was based upon.
If you have created a file based upon an existing file, but you don't
know the revision on which it was based, simply delete the modified
file and start again.
