[GRASS-dev] SVN trunk issue with g.list and g.remove (and solution)
likely you will be affected by this recent issue:
Tree conflict on 'grass_trunk/general/g.list'
   > local dir unversioned, incoming dir add upon update
Select: (r) mark resolved, (p) postpone, (q) quit resolution, (h) help: r
Resolved conflicted state of 'grass_trunk/general/g.list'
Tree conflict on 'grass_trunk/general/g.remove'
svn status | grep -v "^?"
D general/g.list
D general/g.list/Makefile
D general/g.list/g.list.html
D general/g.list/main.c
D general/g.list/testsuite
D general/g.list/testsuite/test_g_list.py
D general/g.remove
D general/g.remove/Makefile
D general/g.remove/check_reclass.c
D general/g.remove/g.remove.html
D general/g.remove/main.c
D general/g.remove/testsuite
D general/g.remove/testsuite/test_g_remove.py
To solve that:
# clean
make distclean
# revert mess
svn -R revert general/g.list
svn -R revert general/g.remove
# update and check
svn up
svn status
I had to do this on all my SVN copies of trunk.
On Tue, Sep 30, 2014 at 3:15 AM, Markus Neteler <neteler@osgeo.org> wrote:
D general/g.list
D general/g.remove
To solve that:
# clean
make distclean
# revert mess
# update and check
svn up
svn status
Confirmed, I had to do the same in all copies too some time ago. SVN is
not really good at renaming and deleting things, it is always confused and
I really don't understand why I need to do revert.
grass-dev mailing list
grass-dev@lists.osgeo.org
On Tue, Sep 30, 2014 at 5:25 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Confirmed, I had to do the same in all copies too some time ago. SVN is not
really good at renaming and deleting things, it is always confused and I
As this almost never happened, it may have been this specific commit
being different from others.
Whatever, the solution we have.
not
Oh, now I hope it was not because I recommended some Git-like procedure to
Huidae which is not really what SVN wanted. Anyway, it was easy to solve
although it required manual intervention to automatic builds (at least the
one for tests).
Hmm… I "remove"d g.list/g.remove and "rename"d g.mlist/g.mremove. Maybe, there is a better way?
really don’t understand why I need to do revert.
Oh, now I hope it was not because I recommended some Git-like procedure to Huidae which is not really what SVN wanted. Anyway, it was easy to solve although it required manual intervention to automatic builds (at least the one for tests).
On Tue, Sep 30, 2014 at 8:16 PM, Huidae Cho <grass4u@gmail.com> wrote:
Hmm... I "remove"d g.list/g.remove and "rename"d g.mlist/g.mremove. Maybe,
In SVN it seems to be a kind a collision since it appears to maintain
the history.
Perhaps the way to go would have been (guessing):
cd general/
svn mv g.list g.list.old
svn mv g.remove g.remove.old
svn ci -m"move old code aside"
svn mv g.mlist g.list
svn mv g.mremove g.remove
svn rm g.list.old
svn rm g.remove.old
svn ci -m"subsitute old g.list/g.remove code with former g.mlist/g.mremove"
Anyway, too late :slight_smile: However, it needs to be manually fixed in all SVN
copies around including the automated builts.
@MartinL: also for winGRASS binaries of trunk
Did you "remove" or "svn remove"? Same for "rename". I guess you did
"svn [remove|rename]", and some other people did not "make distclean"
before "svn up". FWIW, I had no problems with your changes, doing
"make distclean" before "svn up".
Whoever compiles GRASS from source and wants the latest and greatest
(svn up), must clean the source code first with "make distclean"
before recompiling. This applies to all 4 branches. This is not GRASS
specific but the way how svn works.
Markus M
> not
> I
one for tests).
2014-09-30 21:54 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
already done. Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
On Wed, Oct 1, 2014 at 4:43 PM, Markus Metz <markus.metz.giswork@gmail.com>
Maybe,
make distclean or just make clean, this might be it. The message from SVN
was not much helpful, although it changed from the previous version.
But usually you don't have to do make *clean, so how to know these things
ahead (except for looking at Trac)? I don't know. Or is there some option
in SVN (from the options you are given) to use "theirs all" as it was in
previous SVN version (I don't know which)?
Markus M
is
>>> > not
and
>>> > I
to
the
>> one for tests).
>>> Markus
>> _______________________________________________
On Oct 1, 2014 11:49 PM, “Vaclav Petras” <wenzeslaus@gmail.com> wrote:
On Wed, Oct 1, 2014 at 4:43 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Did you “remove” or “svn remove”? Same for “rename”. I guess you did
“svn [remove|rename]”, and some other people did not “make distclean”
before “svn up”. FWIW, I had no problems with your changes, doing
“make distclean” before “svn up”.
(svn up), must clean the source code first with “make distclean”
In this case it failed.
In my cronjob on grass.osgeo.org there well is ‘make distclean’ but the two directories remained wrong unless fixed manually.
markusN
make distclean or just make clean, this might be it. The message from SVN was not much helpful, although it changed from the previous version.
But usually you don’t have to do make *clean, so how to know these things ahead (except for looking at Trac)? I don’t know. Or is there some option in SVN (from the options you are given) to use “theirs all” as it was in previous SVN version (I don’t know which)?
Markus M
not
I
one for tests).
In my case I can confirm Markus M's statement:
make distclean
svn up
worked perfectly...
Moritz
On Thu, Oct 2, 2014 at 10:38 AM, Moritz Lennert
make distclean
svn up
worked perfectly...
As it failed on 4 different systems for me it may be related to the
SVN client version...
Yes, I did "svn remove" and "svn rename". Of course, I had to "make
distclean". IMHO, "svn up" before "make distclean" shouldn't affect
compilation because "make distclean" has nothing to do with the svn
repository, but "make distclean" is necessary after or before "svn up"
anyway.
Huidae
Markus M
>>> > not
>>> > I
>> one for tests).
>>> Markus
   <[1]markus.metz.giswork@gmail.com> wrote:
     On Tue, Sep 30, 2014 at 8:16 PM, Huidae Cho <[2]grass4u@gmail.com>
     wrote:
     > Hmm... I "remove"d g.list/g.remove and "rename"d
     > there is a better way?
     distclean"
   version.
   things ahead (except for looking at Trac)? I don't know. Or is there
   some option in SVN (from the options you are given) to use "theirs all"
   as it was in previous SVN version (I don't know which)?
I guess that when you "svn up", it doesn't clean the OBJ directory in
the old g.list/g.remove directories and old object files conflict with
the new source files?
Huidae
     Markus M
   > On Tue, Sep 30, 2014 at 1:19 PM, Vaclav Petras
   <[3]wenzeslaus@gmail.com> wrote:
   >> On Tue, Sep 30, 2014 at 12:02 PM, Markus Neteler
   <[4]neteler@osgeo.org>
   >> wrote:
   >>> On Tue, Sep 30, 2014 at 5:25 PM, Vaclav Petras
   <[5]wenzeslaus@gmail.com>
   >>> wrote:
   >>> > Confirmed, I had to do the same in all copies too some time ago.
   SVN is
   >>> > not
   >>> > really good at renaming and deleting things, it is always
   confused and
   >>> > I
   >>> > really don't understand why I need to do revert.
   >>> As this almost never happened, it may have been this specific
   commit
   >>> being different from others.
   >>> Whatever, the solution we have.
   >> Oh, now I hope it was not because I recommended some Git-like
   procedure to
   >> Huidae which is not really what SVN wanted. Anyway, it was easy to
   solve
   >> although it required manual intervention to automatic builds (at
   least the
   >> one for tests).
   >>> Markus
   >> _______________________________________________
   >> grass-dev mailing list
   >> [6]grass-dev@lists.osgeo.org
   >> [7]http://lists.osgeo.org/mailman/listinfo/grass-dev
   > [8]grass-dev@lists.osgeo.org
   > [9]http://lists.osgeo.org/mailman/listinfo/grass-dev
References
   1. mailto:markus.metz.giswork@gmail.com
   2. mailto:grass4u@gmail.com
   3. mailto:wenzeslaus@gmail.com
   4. mailto:neteler@osgeo.org
   5. mailto:wenzeslaus@gmail.com
   6. mailto:grass-dev@lists.osgeo.org
   7. http://lists.osgeo.org/mailman/listinfo/grass-dev
   8. mailto:grass-dev@lists.osgeo.org
   9. http://lists.osgeo.org/mailman/listinfo/grass-dev
make distclean
svn up
worked perfectly...
FWIW, here I have
svn, version 1.8.10 (r1615264)
on Debian Testing
Moritz
On Thu, Oct 2, 2014 at 5:38 PM, Moritz Lennert
FWIW, here I have
on Debian Testing
On Wheezy/grass.osgeo.org I have the older
svn, version 1.6.12 (r955767)
     distclean"
   version.
Exactly.
The OBJ directory is not under version control, so svn does not touch
it. That means, svn up can not remove a directory if it contains
anything not under version control, and this can lead to conflicts.
before updating with svn up. This applies to all 4 branches. This is
not GRASS specific but the way how svn works. I did this on different
systems with different svn clients and had no problems.
Markus M
Huidae
     Markus M
   SVN is
   >>> > not
   confused and
   >>> > I
   commit
   procedure to
   solve
   least the
   >> one for tests).
   >>> Markus
References
