[GRASS-dev] Temporal framework: change verbosity of maps registration in temporal DB.
Hello,
I'm writing a module using the temporal framework. I register the
generated maps using register_map_object_list().
The software can generate up to six STRDS. The registration of maps is
quite verbose, cluttering the module output (example bellow).
I can suppress all output by passing the -q flag, but then no other
information is displayed.
Is there a way to silent only the maps registration?
Laurent
WARNING: Overwriting space time raster dataset <out_test_t7_vdir@EA2DT8A>
         and unregistering all maps
Gathering map information...
100%
Registering maps in the temporal database...
Registering maps in the space time dataset...
Updating space time dataset...
100%
WARNING: Overwriting space time raster dataset <out_test_t7_h@EA2DT8A> and
100%
100%
WARNING: Overwriting space time raster dataset <out_test_t7_wse@EA2DT8A>
100%
100%
WARNING: Overwriting space time raster dataset <out_test_t7_v@EA2DT8A> and
100%
100%
