[GRASS-dev] Temporal: t.register: problem parsing when time zone present
input line is:
t.register input=ta maps=ta_2004131 start=“2004-05-10 00:00:00 +0530” end=“2004
-05-10 23:59:59 +0530”
temporal says:
File “/usr/lib/python2.7/sqlite3/dbapi2.py”, line 69, in convert_timestamp
hours, minutes, seconds = map(int, timepart_full[0].split(“:”))
ValueError: invalid literal for int() with base 10: ‘00+05’
Manual says following format accepted:
start=string
Valid start date and time of the first map. Format absolute time: “yyyy-mm-dd HH:MM:SS +HHMM”, relative time is of type integer).
end=string
Valid end date and time of all map. Format absolute time: “yyyy-mm-dd HH:MM:SS +HHMM”, relative time is of type integer).
yann
Hi Yann,
if you need support for time zones you have to use postgresql as
backend. Unfortunately sqlite does not support time zones. A work
around would be to ignore the time zone and use t.shift to temporally
shift the created STRDS by 5h and 30 min to UTC time after registering
the maps. I should notice this in the help page, i don't know why i
missed that ..???!!!
The next thing is that TGRASS uses time intervals in which the end
time is not part of the time interval, but the start time of a
successor. That means that you do not need to know how many days in a
month are; Interval of one day: start="2004-05-10" end="2004-05-11"
Best regards
Soeren
2014-03-05 6:36 GMT+01:00 Yann Chemin <ychemin@gmail.com>:
input line is:
t.register input=ta maps=ta_2004131 start="2004-05-10 00:00:00 +0530"
end="2004
-05-10 23:59:59 +0530"
temporal says:
  File "/usr/lib/python2.7/sqlite3/dbapi2.py", line 69, in convert_timestamp
    hours, minutes, seconds = map(int, timepart_full[0].split(":"))
ValueError: invalid literal for int() with base 10: '00+05'
start=string
"yyyy-mm-dd HH:MM:SS +HHMM", relative time is of type integer).
end=string
Valid end date and time of all map. Format absolute time: "yyyy-mm-dd
yann
Thank you Soeren,
If I want to register an irregular set of daily maps (missing days), will the end date need to be the next day (say 5 days after this image, 2 days after in the next image)?
Yann
On 5 March 2014 12:14, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Yann,
the maps. I should notice this in the help page, i don’t know why i
month are; Interval of one day: start=“2004-05-10” end=“2004-05-11”
Best regards
Soeren
input line is:
end=“2004
temporal says:
start=string
end=string
yann
such a pity you were not in the TGIS workshop.
However, there can be gaps between time intervals.
Hence the end time of a time interval can be start time of a potential
successor or the start time of a gap.
But gaps are not stored explicitly, they are computed by topological analysis
I would suggest that you create an input text file that lists all maps
with time stamps that should be registered
If you call t.register for each single map the registration will be
very inefficient and slow
Example of an input file with gaps between map intervals:
mapA|2001-05-10|2001-05-11
mapB|2001-05-15|2001-05-16
Best regards
Soeren
2014-03-05 9:29 GMT+01:00 Yann Chemin <ychemin@gmail.com>:
Thank you Soeren,
Yann
Hi Yann,
Best regards
Soeren
> Hi,
> input line is:
> end="2004
> temporal says:
> convert_timestamp
> start=string
> end=string
> yann
Yes Soeren, such a pity, I missed all your temporal fun!
As usual, have to do it the hard way…
I will set up the input file, inefficient, but my data is not regular in time…
On 5 March 2014 14:15, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Best regards
Soeren
Thank you Soeren,
Yann
Hi Yann,
Best regards
Soeren
input line is:
end=“2004
temporal says:
convert_timestamp
start=string
end=string
yann
Hi Yann,
2014-03-05 9:48 GMT+01:00 Yann Chemin <ychemin@gmail.com>:
As usual, have to do it the hard way...
I am sorry for that. Are the videos of the workshop ready yet?
time...
Well, TGRASS was designed to support irregular time, hence using an
input file with thousands of maps with irregular time stamps is the
most efficient way to register IMHO.
Why is it in your case inefficient?
Soeren
analysis
Best regards
Soeren
> Thank you Soeren,
> will
> days
> Cheers,
> Yann
> wrote:
>> Hi Yann,
>> Best regards
>> Soeren
>> > Hi,
>> > input line is:
>> > end="2004
>> > temporal says:
>> > convert_timestamp
>> > start=string
>> > end=string
>> > yann
I will contact Aruna to check about the videos…
I just repeated inefficient from:
On 5 March 2014 14:30, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Yann,
time…
Soeren
analysis
Best regards
Soeren
Thank you Soeren,
will
days
Yann
wrote:
Hi Yann,
Best regards
Soeren
input line is:
end=“2004
temporal says:
convert_timestamp
start=string
end=string
yann
