[GRASS-dev] time to release 6.2.2
during the testing period of 6.2.2-RC1 we got the following
issues fixed:
    * DBF driver: fix semicolon problem (Glynn Clements)
    * SQLite transactions to speed up execute (Antonio Galea)
    * GUI startup: fixes browsing for EPSG file not updating path to it (Maris Nartiss)
    * GUI startup: fixes browsing for new location path (Maris Nartiss)
    * nviz compilation fix for MacOSX (Markus Neteler)
    * r.in.gdalwarp: remove bashisms (Hamish Bowman)
    * v.dissolve: fix for DBMI error if input map is specified with @mapset (Markus Neteler)
    * v.lrs.* fixes backported + new documentation (Markus Neteler)
    * Czech translation updated (Jachym Cepicky)
See
http://grass.gdf-hannover.de/wiki/GRASS_6.2_Feature_Plan#Fixed_post-RC1
I would suggest to release 6.2.2 officially the next days if nobody
objects.
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
FBK-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Hello Markus
As I noted before (http://grass.itc.it/pipermail/grass-dev/2007-May/031699.html) Grass 6.2.2 seems to already be tagged (as grass_6_2_2) in CVS. I wonder how/when this happened, but it was definitely before 28th May as that was when I sent that e-mail. I still think it is a good idea to include the date of releases in the tag name, less confusion that way, e.g. release_20070702_grass_6_2_2 - what do you think? Or is there any other way of telling from CVS on what date the tag was created?
Paul
On Sun, 1 Jul 2007, Markus Neteler wrote:
issues fixed:
See
objects.
grass-dev mailing list
grass-dev@grass.itc.it
Markus:
objects.
While at sea I found a glitch with v.in.gpsbabel on the Mac which I'd like to
fix before release. (unportable call to "stat -c%s" for file size during XML
parsing; replaced with "wc -c")
I've a huge pile of data, unpacking, and gear repairs stacked up in the middle
of my lab to deal with, but I'll try to get the fix into CVS later today or
tomorrow.
Hamish
____________________________________________________________________________________
Food fight? Enjoy some healthy debate
in the Yahoo! Answers Food & Drink Q&A.
http://answers.yahoo.com/dir/?link=list&sid=396545367
OK by me.
Michael
On 7/1/07 12:05 PM, "Markus Neteler" <neteler@itc.it> wrote:
issues fixed:
Nartiss)
(Markus Neteler)
See
objects.
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Paul Kelly wrote on 07/01/2007 10:13 PM:
Hello Markus
As I noted before
Mea culpa! I want to shift this tag now to remove the mess. The "enter"
key was too close,
I hit it before starting thinking. Sorry.
I don't know but I remember that someone (Glynn?) suggested to NOT
include the
date so that it wasn't done any more.
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
include the
Well that's fine then if it has been discussed - I guess I just missed that when it happened but there were I'm sure good reasons for it then. FWIW my reasons for keeping with the old-style tags would be (a) less likely to create a tag by accident as you're putting a meaningful date into it and have to stop and think about that and (b) easy quick reference looking back through the web-based CVS browser as to the dates of the earlier releases.
But neither of those are particularly important. Good luck in shifting the tag!
Paul
Paul Kelly wrote on 07/02/2007 11:33 AM:
include the
the tag!
I found this documentation:
http://cvsnt.org/manual/html/Modifying-tags.html
Anyone with experience...?
thanks
include the date so that it wasn't done any more.
I don't have any recollection of that.
>> include the
> the tag!
If you want to discard the existing grass_6_2_2 tag and tag the
current version:
  cvs rtag -d grass_6_2_2 grass6
  cvs tag -c release_20070702_grass_6_2_2
If you just want to rename the existing tag, ignoring any updates on
the branch:
  cvs rtag -r grass_6_2_2 release_20070702_grass_6_2_2 grass6
Markus:
objects.
Hamish:
I found a glitch with v.in.gpsbabel on the Mac which I'd like to fix
before release.
done.
Paul:
As I noted before (..) Grass 6.2.2 seems to already be tagged (as
I agree, it reduces confusion about a CVS tag being a conceptual alias
to a timestamp, as opposed to a separate working CVS branch line.
"grass_x_y_z" by itself is easily confused with a release branch line.
summary of previously used tags:
  http://freegis.org/cgi-bin/viewcvs.cgi/grass/GPL.TXT
  http://freegis.org/cgi-bin/viewcvs.cgi/grass6/GPL.TXT
"release_YYYYMMDD_grass_x_y_z" (or "YYYYMMDD_grass_x_y_z", or some other
combination) sorts well.
nb. "release" and "grass" may be redundant noise in the tag name
Paul:
Markus:
Glynn:
current version:
see also
  http://article.gmane.org/gmane.comp.gis.grass.devel/21022
Hamish
Glynn Clements wrote on 07/02/2007 09:22 PM:
Deleting, moving, and renaming tags
current version:
Tag removed. Now we can start with more sensible tag names :slight_smile:
Glynn Clements wrote on 07/02/2007 09:11 PM:
Ok.
Since everybody is happy, we'll re-introduce the date into the tag.
Markus Neteler escribió:
issues fixed:
What about the other languages? Will they be included in the new release and packages?
Carlos
issues fixed:
and packages?
Carlos
Carlos,
would be great to merge back. But I tried once and actually *lost*
many messages. So, after a try one must check if this doesn't
reduce the translations in 6.2.x.
I can send you a script "po_merge.sh" which does it for all 3 files
automatically The script will ask you for the country code and then
it uses "msgmerge". The script is just a few lines.
View this message in context: http://www.nabble.com/time-to-release-6.2.2-tf4008762.html#a11455121
Sent from the Grass - Dev mailing list archive at Nabble.com.
issues fixed:
Carlos
Carlos,
I already had the script. I've done a test with es.po files and this is the result:
libs: same total and more fuzzy, so discarded.
mods and tcl: total amount of messages raises from 3910 and 871 to 4775 and 1148 respectively. Are all these new messages useful in 6.2.2 or I shall look only to the variation in fuzzy and untranslated? Shall I make pot & make update-po after running the script?
As you can see, many doubts.
Regards
Carlos
Carlos Dávila wrote on 07/06/2007 12:49 PM:
issues fixed:
Carlos
Carlos,
is the result:
I think that only "good" messages count (so, translated, non-fuzzy) and the
rest isn't important. If you observe a growing number of correctly
translated messages,
then I suggest to submit to 6.2.cvs.
proposal: tag 6.2.2rc2 circa now, and if no more major changes are applied
release it mostly unchanged as 6.2.2 final in the next 2 weeks.
  aka
any more outstanding issues that are reasonably expected to be fixed?
I think it is late in the game to start thinking about backporting
translations; iff there is a chance of regressions (?).
(Markus, does your pull-in script only add in new untranslated messages,
vs wholesale replacement of the .po files based on some a>b test? I
worry a bit if the entire file is replaced based on a a>b basis)
AFAICT, we're ready to go.
Hamish
  aka
Tag, but please do NOT release 6.2.2 until I get a reply on the
directory permission/security issue I sent to the list over the weekend.
This is a show-stopper until explained or fixed, IMHO. I'm sure you'll
all agree when user X does 'rm -rf *' on your working dir. :wink:
73, de Brad KB8UYR/6 <rez touchofmadness com>
Hamish wrote on 07/09/2007 11:44 AM:
  aka
The v.in.gns patch needs to be applied I think.
And my todays v.db.addtable bugfix needs a test
The script only runs msgmerge in a convenient way, so it is up to gettext.
Yes, almost.
Last Friday I applied Markus script to all languages po files and sent to cvs (releasebranch_6_2 grass6) all those with increased number of translated messages, so it's supposed current translations are backported. As it's the first time I work with this branch, could anyone check I sent them to the right place?
Regards
Carlos
