[GRASS-dev] Two new strange behaviours in GRASS 6.4.1SVN
Dear list,
I noticed two strange new things in 6.4.1svn that may
both be related to the recent GUI changes.
1. I configured and compiled GRASS explicitely without
Tcl/Tk and without Python support. The configure script
correctly reported a "No" for both options.
Yet if I just run e.g. "r.out.gdal" (i.e. with no options
or flags), I get:
python: can't open file '/usr/local/grass-6.4.1svn/etc/wxpython/gui_modules/menuform.py': [Errno 2] No such file or directory
Whereas I would expect the synopsis to be displayed in
a CLI-only environment. And I really didn't want GRASS
to interact with my system's Python at all.
2. The --help flag is only interpreted correctly depending
on its position on the CLI. This:
  r.out.gdal --help input=aspect output=aspect.tiff
correctly displays the module synopsis, but this:
  r.out.gdal input=aspect output=aspect.tiff --help
gives:
  Sorry, <-> is not a valid flag
  Sorry, <h> is not a valid flag
  Sorry, <e> is not a valid flag
  Sorry, <p> is not a valid flag
which is unfortunated, because I often type a CLI up
to the point I can remember it and then add --help to
get a reminder of the rest.
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
On Fri, Jan 14, 2011 at 1:24 PM, Benjamin Ducke
<benjamin.ducke@oxfordarch.co.uk> wrote:
Dear list,
or flags), I get:
(no idea unfortunately)
gives:
Same problem here! It would be good to have that back, it
must be a change in lib/gis/parser.c causing this. Looks like
this?
http://trac.osgeo.org/grass/changeset/45025/grass/branches/releasebranch_6_4/lib/gis/parser.c
2011/1/14 Benjamin Ducke <benjamin.ducke@oxfordarch.co.uk>:
gives:
fixed in r45025.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
or flags), I get:
There isn't a way to disable this behaviour, although you can choose
between Tcl/Tk and Python using the GRASS_GUI environment variable, or
a select terminal-based interaction by setting GRASS_UI_TERM. It isn't
a new feature; it has always been this way (before the GUI dialogs
were implemented, you would always get the terminal-based
interaction).
If you want the synopsis, you have to explicitly use the "help"
option.
--without-python and --without-tcltk disable the checks for libraries
and header files, and thus the ability to compile code which uses
those libraries. They don't have any effect upon code which invokes
the python/wish interpreters via system() etc.
or flags), I get:
hm, this file should be installed regardless python configures switch.
Martin
