[GRASS-dev] v.clean meters against feets
Hi everybody,
I'm testing v.clean with meters and feet projection system.
I'm trying to run v.clean in the same map and with the same
parameters, but I obtain a different result. For the testing I'm using
zipcodes_wake map of nc_spm_08
Here my procedure:
- download nc_spf location from here [0]
- reproject zipcodes_wake from nc_spm_08 to nc_spf
- run v.clean on meters location with "v.clean in=zipcodes_wake
out=zipcodes_wake_clean tool=rmarea thre=10000000" the result is
Number of nodes: 106
Number of primitives: 166
Number of points: 0
Number of lines: 0
Number of boundaries: 135
Number of centroids: 31
Number of areas: 31
Number of isles: 2
- run v.clean on feet location with "v.clean in=zipcodes_wake
out=zipcodes_wake_clean tool=rmarea thre=107638674"
Number of nodes: 84
Number of primitives: 103
Number of points: 0
Number of lines: 0
Number of boundaries: 93
Number of centroids: 10
Number of areas: 10
Number of isles: 1
The threshold in feet should be the same of the meters one because:
1 meters is 0.3048006096012192 feet (according with g.proj output)
and
10000000 squared meters is 107638674 squared feet ( 10000000 / 0.3048^2 )
I expected the same output map, but this not happen; I'm wrong or
there is something wrong in the v.clean code?
[0] http://grass.osgeo.org/sampledata/north_carolina/nc_spf.tar.gz
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
On 27/08/14 10:01, Luca Delucchi wrote:
Hi everybody,
Here my procedure:
Number of points: 0
Number of lines: 0
Number of areas: 31
Number of isles: 2
Number of nodes: 84
Number of points: 0
Number of lines: 0
Number of areas: 10
Number of isles: 1
and
Have you compared the topo information of the two files before v.clean ? Maybe reprojection changes some of the topology (i.e. some lines do not close, or something similar) ?
Moritz
On Wed, Aug 27, 2014 at 10:01 AM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Hi everybody,
Here my procedure:
Number of points: 0
Number of lines: 0
Number of areas: 31
Number of isles: 2
Number of nodes: 84
Number of points: 0
Number of lines: 0
Number of areas: 10
Number of isles: 1
The threshold must always be in meters, also if the location's units
are not meters, because G_area_of_polygon() is used to calculate area
sizes which always returns square meters. This was wrong in the manual
of v.clean, fixed in r62047,8 (trunk, relbr70).
Markus M
and
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
On Mon, Sep 22, 2014 at 9:04 AM, Markus Metz
Thanks for the clarification. I'd suggest to then also fix the
parameter description since "map units" may be ambiguous in some
cases:
threshold=float[,float,...]
  Threshold in map units, one value for each toolDefault: 0.0[,0.0,...])
markusN
On 22 September 2014 09:04, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Ok, now the results are identical
Thanks
Markus M
ciao
Luca
www.lucadelu.org
