[GRASS-dev] v.edit
Ok now v.edit's add functionality is completed. One can add point,line,area,boundary,centroid. Boundaries will not be given a cat.
Adding an area tries to put a centroid in the geographic mean, and if it fails it will exit, with nothing added.
if you give many co-ordinates when adding a point many points will be generated.
The cat support includes support for many cat's and ranges. This is for instance supported:
   v.edit map=test cat=267,347-350,353,356-359 coords=...
And if there are more points then given cats, the cat will just be increased by one. The example above will result in 10 cats:
267,347,348,349,350,353,356,357,358 and 359. If you give 11 point the eleventh point will get the next cat (which is 360)
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
Hallo,
great work
generated.
instance supported:
--Wolf
Why should a boundary NOT have category too? How would you distinguish
two different types of boundary arround one area? Example on
http://les-ejk.cz/tmp/boundaries.gif
One country (Sachsen) has 2 different types of boundaries (country and
state).
I thing, it is usefull to have a possibility for adding category number
(and attributes) to boundary too.
Or do I understand it wrong?
Jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
At the moment because that is the way I coded, and I haven't seen a boundary with a cat yet. I can quite easily change it, if you think I should.
While we are talking about all this. Is there any such thing as an open boundary (a line of type GV_BOUNDARY that has different first and last points? As I understand it boundaries are lines that define the shape of an area and the centroid marks the "inside" of the area. So that way boundaries are not really part of the area, but rather marks its extents.
--W
state).
number (and attributes) to boundary too.
It can have its uses. You can give a boundary a cat with v.category if
you want.
In general it isn't needed, and worse can subtly change things (like
v.to.rast output) so should be used with caution.
v.edit could have the power to add boundary cats, just leave it out of
the GUI controls :wink:
Hamish
its extents.
Yes, try making one with the (old) v.digit. (red endpoints).
on exit:
Topology was built.
Number of nodes : 2
Number of primitives: 1
Number of points : 0
Number of lines : 0
Number of boundaries: 1
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Number of incorrect boundaries : 1
Hamish
you want.
Hamish
Did you see the last version of v.pydigit? Is that desired setting and behaviour ?
Jachym
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
donut case? kidney shape ("C")?
Use Vect_get_point_in_area() to find a centroid that is really in the
area.
see v.category add GV_AREA.
[It tests for an existing one first with Vect_get_area_centroid()]
the vector lib has most common tools aready....
Hamish
Currently it will print an error message and exit. ):
area.
Thanks! I'll look in to it. (:
--W
This sounds great.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 6 Jun 2006 10:30:47 +0300 (EEST)
To: GRASS developers list <grass-dev@grass.itc.it>
Subject: [GRASS-dev] v.edit
generated.
instance supported:
--Wolf
Jachym,
See below
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 6 Jun 2006 11:43:05 +0200
To: Wolf Bergenheim <wolf+grass@bergenheim.net>
Cc: GRASS developers list <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] v.edit
Hallo,
great work
generated.
instance supported:
--Wolf
state).
You can also think of this conceptually as 2 different areas (country and
state) that overlay. Or the area can simply have 2 attributes or even 2
layers (a state layer and a country layer). So there are a number of ways
to represent this situation.
As I said earlier, while it sometimes might be convenient for a boundary to
have a cat (with possibility of attributes) separate from that of an area, I
think it is better to make boundaries different from lines.
A line can be open or closed, has a cat and attributes. It is a vector
entity.
A boundary, while internally structured like a line, is part of a complex
entity called area. The complex area entity is composed of a closed line and
a point, and has a single cat for the closed line/point pair.
I think this kind of definition would make entity creation and management
easier than it is now. A boundary that is not part of an area and is not a
closed line is an odd, confusing entity IMHO. Could be convenient, I admit,
but I think that we are better off without it.
Michael
Jachym
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
I agree with Michael. I think that we should strive to make the
topologic model as orthogonal as possible. More importantly, it should
be easy to understand and implement. Tools should enforce the model
not add to the confusion. One of the problems of operational GIS are
broken/unclean topology.
If we need more sophisticated topological entities than point, line,
area; then we should develop a higher-order topologic model that is
built out of the three primitive objects rather than hack the simple
model. For example, boundary lines for a single area with distinct
categories are merging the behavior of line entity with the area
entity. I think that is confusing.
On 6/6/06, Michael Barton <michael.barton@asu.edu> wrote:
Jachym,
See below
Michael
phone: 480-965-6213
fax: 480-965-7671
> From: Jachym Cepicky <jachym.cepicky@centrum.cz>
> Hallo,
> great work
>> generated.
>> instance supported:
>> --Wolf
> state).
entity.
Michael
> Jachym
> Jachym Cepicky
> OFFICE:
> GDF-Hannover
> Mengendamm 16d
> 30177 Hannover
> Germany
grass-dev mailing list
David Finlayson
