Dears,
I get something unexpected using type=boundary with `v.external`:
v.extract input=european_grid_10k_boundaries out=test type=boundary --v --o
Using native format
Extracting features...
100%
Building topology for vector map <test@PERMANENT>...
Registering primitives...
0 primitives registered
0 vertices registered
Topology was built
Number of nodes: 0
Number of primitives: 0
Number of points: 0
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
Writing attributes...
I tried this in both 7.4 and trunk.
The map does have boundaries,
v.info -t european_grid_10k_boundaries
nodes=253
points=0
lines=0
boundaries=422
centroids=177
areas=177
islands=8
primitives=599
map3d=0
I can draw the boundaries on-screen using `d.vect type=boundary`.
The vector map is small, so I have attached it here-in, in case someone
can have a quick look.
Thank you, Nikos
(attachments)
european_grid_10k_boundaries.grasspack (29 KB)
* Nikos Alexandris <nik@nikosalexandris.net> [2018-05-04 16:09:38 +0200]:
Dears,
It's only `v.extract`, `v.external` has nothing to do with here. Sorry.
Nikos
On Fri, May 4, 2018 at 4:09 PM, Nikos Alexandris <nik@nikosalexandris.net> wrote:
Dears,
I get something unexpected using type=boundary with v.external:
Using native format
100%
Topology was built
Number of nodes: 0
Number of points: 0
Number of lines: 0
Number of areas: 0
Number of isles: 0
The default answer for the layer option of v.extract is 1, i.e. only features with a category in layer 1 will be extracted. If you want to extract all features of a given type, use e.g. v.extract layer=-1 type=boundary.
Markus M
[v.info](http://v.info) -t european_grid_10k_boundaries
nodes=253
points=0
lines=0
boundaries=422
centroids=177
areas=177
islands=8
primitives=599
map3d=0
I can draw the boundaries on-screen using d.vect type=boundary.
Thank you, Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
* Markus Metz <markus.metz.giswork@gmail.com> [2018-05-04 16:41:59 +0200]:
wrote:
Dears,
–o
Using native format
Extracting features…
100%
Building topology for vector map test@PERMANENT…
Registering primitives…
Topology was built
Number of nodes: 0
Number of points: 0
Number of lines: 0
Number of areas: 0
Number of isles: 0
Writing attributes…
type=boundary.
Markus M
Understood, it works. It's also in the NOTES of the manual, which I
obviously missed to read carefully.
Thank you Markus
