[GRASS-dev] v.in.ogr: tmp file error
I observed two new problems in the current 7.0.3 when importing a SHAPE file:
GRASS 7.0.3svn (eu_laea):~/ > v.in.ogr something.shp out=bla
Check if OGR layer <something> contains polygons...
100%
Importing 2 features (OGR layer <something>)...
100%
Registering primitives...
2 primitives registered
10 vertices registered
Number of nodes: 2
Number of primitives: 2
Number of points: 0
2 input polygons
Total area: 3.41002E+09 (2 areas)
Copying features...
100%
.WARNING: Unable to remove directory
         '/grassdata/eu_laea/neteler/.tmp/pgis_north/9975.0' <---- ???
Building topology for vector map <bla@neteler>...
Number of areas: 2
Number of isles: 2
The map is there.
Was the temp file management modified in v.in.ogr (or is it DBMI
related) lately?
2015-12-22 13:50 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
I cannot reproduce this error, please could you send some debug
messages around? Thanks, Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Tue, Dec 22, 2015 at 2:03 PM, Martin Landa <landa.martin@gmail.com> wrote:
Apparently my sqlite DB was corrupted (no idea why).
I did a SQL dump and recreated it from that, now also that error is gone.
Will keep an eye on it.
