For this reason, v.info always prints out "Projection: x,y (zone ...)"
(Map.proj == 0 == PROJECTION_XY) regardless of its actual projection.
It seems like to me there is no projection info in vector files. If
individual vector files cannot have a different projection from its
location, why doesn't v.info use G_database_projection_name() like
r.info does?
I found that Vect_open_old_head() does not set Map.proj:
<snip>
r.info does?
Since this issue is rised, I'd like throw my 0,01 PLN in. Why, in the
first place, does r.info or v.info even try to print the projection
info? I don't think they should. It is pointless - all the maps within
one Location have the same projection anyway. For querying the
Location's projection info there is g.proj -p. And also the g.region
-p, but same as in case of *.info modules, I believe it shouldn't do
that - g.region should be concerned with the region extent and
resolution only. It would be enough if it just distunguished between
lat/long, projected and xy, and not go into ellipsoids/datums/zones
details and stuff - there is g.proj for that.
What do you think? Removing this code alltogether from *.info would let
us get rid of bogus, missleading r.info output in the kind of
"Projection: Latitude-Longitude (zone 0)" as well. Propably not a plan
for GRASS 6, but how about 7?
On Tue, Oct 24, 2006 at 09:22:40AM +0200, Maciej Sieczka wrote:
Huidae Cho wrote:
> Hi,
<snip>
> r.info does?
I've been thinking about that. I personally like only one way for one
task. We can avoid inconsistent/erroneous outputs in this way.
Huidae
> Huidae Cho wrote:
> > Hi,
> <snip>
> > r.info does?
> Hi,
Huidae
> Maciek
I'd throw in my $0.02 as well: I agree with Maciek and Huidae.
Now the question remains: how much money do we have now?
$0.02 + 0,01 PLN + ???
hehe
cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
