I was testing the v.net.distance (in QGIS) and noticed something strange. Apparently the route is calculated in a reverse way.
If you see in this screencast
https://dl.dropboxusercontent.com/u/5772257/qgis/processing_grass_v_net_distance.ogv
I have a network of streets with two-way (green) and some with only one-way (in red, with the arrow indicating the direction of traffic). The two-way cost is in “dois_senti” field of the attribute table, and the sections of one-way have -1 value in the “um_senti” field of the attribute table.
The starting point is the orange pentagon (“ponto_inicio”), and the destination point is the green star (“ponto_chegada”).
As you can see, v.net.distance calculate the route in the reverse way, that is, when I choose “ponto_inicio” as “from”, and “ponto_chegada” as “to” (first run in the screencast), it gives me the route by the south (“ponto_chegada” → “ponto_inicio”). In the second run, I choose “ponto_chegada” as “from”, and “ponto_inicio” as “to”, and it uses the one-way street. So, the topology is respected, but it seems that “from” and “to” are used in a reverse manner.
I thought it might be a mistake in implementing the tool in QGIS Processing, but then I performed the same procedure on GRASS 7.0.2 native, and the result is the same.
Médéric Ribreux has done also some tests and concluded that from_layer is used as to_layer.
It seems to be a GRASS problem because the point layers order is correct:
- layer 2 is imported from FROM_CENTERS QGIS layer.
- layer 3 is imported from TO_CENTERS QGIS layer.
- layer 2 is used as from_layer in v.net.distance.
- layer 3 is used as to_layer in v.net.distance.
He has tried with v.net.path and got the same results than for v.net.distance.
Could it be a mis-interpretation of forward and backward costs? A bug? Or simply how the tool works?
Thanks!
Best regards,
Pedro
