Dear GRASS GIS developers,
I am planning to use v.perturb to run a spatial simulated annealing exercise. Two drawbacks with v.perturb exist. First, “output vector points are not guaranteed to be contained within the current geographic region”. Second, all vector points are perturbed together.
Is it very difficult to solve this issues?
Another option for perturbation would be v.edit, but in that case the direction and distance are not random.
Best,
Alessandro Samuel-Rosa
Graduate School in Agronomy - Soil Science
Federal Rural University of Rio de Janeiro
Seropédica, Rio de Janeiro, Brazil
Guest Researcher at ISRIC - World Soil Information
Wageningen, the Netherlands
Homepage: soil-scientist.net Skype: alessandrosamuel
exercise. Two drawbacks with v.perturb exist. First, "output vector
region". Second, all vector points are perturbed together.
What exactly are your objectives ?
You can use v.extract with the random= option or v.kcv+v.extract to create a sample of points you can then perturb instead of perturbing all points.
To make sure your points still fall into the region, you can use v.in.region to create a polygon representing the region, then v.select within your sample those that fall into the polygon.
Moritz
My objective is to perform a spatial simulated annealing schedule. It works as follows:
- generate a set of n points randomly positioned in the study area (v.random);
- query values from raster maps (r.what);
- calculate an statistic;
- randomly perturb one randomly selected point;
- the point has to fall withing the study area;
- go through 2-4 till the statistic meets a given criterion.
Ideally, v.perturb would do step 4: allow for perturbing a single point and check if it still falls inside the study area. If the point falls outside the study area, then it should be forced to the closest position within the study area.
Em Quinta-feira, 28 de Agosto de 2014 13:49, Moritz Lennert mlennert@club.worldonline.be escreveu:
points.
Moritz
works as follows:
1) generate a set of n points randomly positioned in the study area
(v.random);
2) query values from raster maps (r.what);
3) calculate an statistic;
4) randomly perturb one randomly selected point;
5) go through 2-4 till the statistic meets a given criterion.
Until someone adds this functionality to v.perturb, you could just use a loop like this:
- v.extract your point (possibly v.extract -r the other points)
- perturb extracted point
- while point outside region (you can check either mathematically using the points coordinates that you can get via v.to.db or you can use v.select the point with the region polygon and check whether the result is empty or no)
- perturb the point again
Moritz
I will follow your suggestion as far such functionality is not implemented in v.perturb.
Em Quinta-feira, 28 de Agosto de 2014 15:09, Moritz Lennert mlennert@club.worldonline.be escreveu:
works as follows:
(v.random);
loop like this:
is empty or no)
Moritz
Attached a very crude and untested attempt at a region check. If you can compile GRASS, you could try to see if it works. It should probably be made conditional on a flag as most people would not expect a vector module to take region settings into account.
You can also file an enhancement request in the GRASS Trac.
Moritz
(attachments)
perturb_regioncheck.diff (1.26 KB)
On Aug 27, 2014 12:12 AM, “Alessandro Samuel Rosa” <alessandrosamuel@yahoo.com.br> wrote:
The command v.random got recently improved to optionally constrain points being generated to a restricted area. Not sure if this method could be implemented here as well.
Did you test how far outside points may fall?
Here a “where” statement would help, to be implemented…
Best,
grass-dev mailing list
grass-dev@lists.osgeo.org
The place where a point will fall depends on the arguments “distribution” and “parameters”. In spatial simulated annealing we start allowing a point to be shifted (perturbed) to any location within the study area. As the iterations go on, we constrain the amount of shifting to shorter distances.
Regarding v.random: could you please include a description in the help page on how the restriction is done? This is an extremely important information.
Em Quinta-feira, 28 de Agosto de 2014 17:28, Markus Neteler neteler@osgeo.org escreveu:
Best,
On Fri, Aug 29, 2014 at 8:37 AM, Alessandro Samuel Rosa
It is all there:
http://grass.osgeo.org/grass70/manuals/v.random.html#restriction-to-vector-areas
