I can not get reasonable result (compared with v.surf.rst) from
v.surf.idw using attached input vector points
is it possible, that v.surf.idw is kind of broken?
[xy location]
v.in.ogr dsn=vzorky.shp out=vzorky
v.surf.idw in=vzorky out=dpidw column=dp
v.surf.rst in=vzorky elev=dprst zcolumn=dp
thanks
jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
(attachments)
vzorky.zip (20.6 KB)
On Tue, 13 Apr 2010, Jachym Cepicky wrote:
Hello,
I can confirm that I can reproduce the strangeness, that it only happens when *not* using the -n flag (i.e. when indexing points) and that it happens when interpolating a relatively small number of points into a region with a relatively high resolution. E.g. for the given data I observe strangeness for a resolution of 10, but it goes away either by specifying the -n flag or decreasing the resolution to 15.
It does indeed look to be caused by my buggy code from 2003, or (perhaps less likely; I'm not sure) some later change to it - specifcally something to do with the "shortlist" method of avoiding an intensive search for nearby sites/points when the number of points is relatively small compared to the region size.
I can't see anything obviously wrong but I'll look into it over the next few days...
Paul
Thanks
I can confirm, that using -n flag works
Jachym
2010/4/13 Paul Kelly <paul-grass@stjohnspoint.co.uk>:
Hello,
region size.
days...
Paul
Jachym Cepicky
