[GRASS-dev] v.to.db option=slope
Hallo,
somebody asked on IRC, how to calculate slopes for vector lines.
This patch should add new option "slope" to v.to.db module and calculate slope steepness
for each vector line
What do you think, shall I commit this patch to cvs?
Jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
OFFICE:
Department of Geoinformation Technologies
Zemedelska 3
613 00, Brno
Czech Republick
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
(attachments)
v.to.db-slope.patch (6.59 KB)
On Thu, Dec 07, 2006 at 05:30:00PM +0100, Jachym Cepicky wrote:
Hallo,
Hi Jachym,
nice idea! Without inspecting the patch, does it work in LatLong?
Interesting patch Jachym!
Out of curiosity, and not being able to extract it from the patch, how
exactly does this approach work? Are you caclulating a slope between
vertices of a 3D vector?
Looking forward to learning more about it!
Great job,
Dylan
On 12/7/06, Jachym Cepicky <jachym.cepicky@centrum.cz> wrote:
Hallo,
Jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (GNU/Linux)
iD8DBQFFeEGIyKt0uAjU4I8RAnlMAJ0R7J0aHMDAQ9rLIO9Ch3tJw03UTwCgomsY
wa4JKzCgM8UPheYO55p3fA4=
=F/eE
-----END PGP SIGNATURE-----
grass-dev mailing list
grass-dev@grass.itc.it
hi,
> Hallo,
Hi Jachym,
no, it does not :frowning: it does not even work with option=length, because of
Vect_cidx_get_num_unique_cats_by_index ( &Map, Vect_cidx_get_field_index(&Map, options.field ) );
in main.c returns 1634887471 of unique cats by index and v.to.db ends up
with G_calloc error: could not allocat memory.
I have no clue, how to fix this bug.
Jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
hi,
it works very simply:
    (z_end - z_start)/length2d
so you get _approximated_ slope for whole line. e.g.
   `---ยด
would result into slope=0
Great job,
just a small patch :wink:
Dylan
thanks
jachym
>Hallo,
>slope steepness
>Jachym
>Jachym Cepicky
>OFFICE:
>Zemedelska 3
>613 00, Brno
>Czech Republick
>=F/eE
>_______________________________________________
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
hi,
since nobody really complained, I commited the patch. v.to.db has new
option "slope" now
jachym
Hallo,
Jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
Index: vector/v.to.db/global.h
RCS file: /grassrepository/grass6/vector/v.to.db/global.h,v
retrieving revision 1.8
diff -u -r1.8 global.h
--- vector/v.to.db/global.h 9 Feb 2006 03:09:07 -0000 1.8
+++ vector/v.to.db/global.h 7 Dec 2006 16:21:18 -0000
@@ -13,7 +13,7 @@
                             /* for sides set to 2, if more than 1 area category was found, */
                             /* including no category (cat = -1)! */
     int i1,i2; /* values; i1: query (result int), sides; i2: sides */
- double d1,d2,d3; /* values (length, area, x/y/z, query) */
+ double d1,d2,d3,d4; /* values (length, area, x/y/z, query, slope) */
     char *str1; /* string value (query) */
     int *qcat; /* array query categories */
     int nqcats; /* number of query cats */
@@ -65,6 +65,8 @@
#define O_START 10 /* line/boundary starting point */
#define O_END 11 /* line/boundary end point */
+#define O_SLOPE 12 /* Line slope */
#define U_ACRES 1
#define U_HECTARES 2
Index: vector/v.to.db/lines.c
RCS file: /grassrepository/grass6/vector/v.to.db/lines.c,v
diff -u -r1.8 lines.c
--- vector/v.to.db/lines.c 9 Feb 2006 03:09:07 -0000 1.8
+++ vector/v.to.db/lines.c 7 Dec 2006 16:21:18 -0000
@@ -48,7 +48,7 @@
  * Read: - points/centroids : cat,count,coor
- * - lines/boundaries : cat,count,length
+ * - lines/boundaries : cat,count,length,slope
int
@@ -58,7 +58,7 @@
     register int line_num;
     struct line_pnts *Points;
     struct line_cats *Cats, *LCats, *RCats;
- double len;
+ double len,slope;
     /* Initialize the Point struct */
     Points = Vect_new_line_struct();
@@ -137,7 +137,13 @@
                     read_side_cats ( LCats, &(Values[idx].i1), &(Values[idx].count1) );
                     read_side_cats ( RCats, &(Values[idx].i2), &(Values[idx].count2) );
+ } else if ( options.option == O_SLOPE && (type & GV_LINES) ) {
+ /* Calculate line slope */
+ len = length (Points->n_points, Points->x, Points->y);
+ slope = (Points->z[Points->n_points-1] - Points->z[0])/len;
+ Values[idx].d1 += slope;
     found = 1;
@@ -167,7 +173,13 @@
       } else if ( options.option == O_SIDES && type == GV_BOUNDARY ) {
Index: vector/v.to.db/parse.c
RCS file: /grassrepository/grass6/vector/v.to.db/parse.c,v
retrieving revision 1.19
diff -u -r1.19 parse.c
--- vector/v.to.db/parse.c 21 Sep 2006 12:50:39 -0000 1.19
+++ vector/v.to.db/parse.c 7 Dec 2006 16:21:18 -0000
@@ -48,7 +48,7 @@
     parms.option->type = TYPE_STRING;
     parms.option->required = YES;
     parms.option->multiple = NO;
- parms.option->options = "cat,area,compact,perimeter,length,count,coor,start,end,sides,query";
+ parms.option->options = "cat,area,compact,perimeter,length,count,coor,start,end,sides,query,slope";
     parms.option->description = _("Value to upload");
     parms.option->descriptions =
      "cat;insert new row for each category if doesn't exist yet;"
@@ -64,7 +64,8 @@
      "sides;categories of areas on the left and right side of the boundary, "
            "'qlayer' is used for area category;"
      "query;result of a database query for all records of the geometry"
- "(or geometries) from table specified by 'qlayer' option";
+ "(or geometries) from table specified by 'qlayer' option;"
+ "slope;slope steepness of vector line or boundary";
     parms.units = G_define_option();
     parms.units->key = "units";
@@ -100,7 +101,7 @@
     flags.t = G_define_flag();
     flags.t->key = 'c';
- flags.t->description = _("In print mode prints totals for options: length,area,count");
+ flags.t->description = _("In print mode prints totals for options: length,area");
     if (G_parser(argc,argv)) exit(EXIT_FAILURE);
@@ -132,7 +133,7 @@
     if ( options.option == O_AREA || options.option == O_LENGTH || options.option == O_COUNT
- || options.option == O_QUERY || options.option == O_COMPACT || options.option == O_PERIMETER) /* one column required */
+ || options.option == O_QUERY || options.option == O_COMPACT || options.option == O_PERIMETER || options.option == O_SLOPE ) /* one column required */
   if ( ncols != 1 ) {
       G_fatal_error ( _("This option requires one column") );
@@ -187,6 +188,7 @@
     else if (strcmp (s, "query") == 0) x = O_QUERY;
     else if (strcmp (s, "compact") == 0) x = O_COMPACT;
     else if (strcmp (s, "perimeter") == 0) x = O_PERIMETER;
+ else if (strcmp (s, "slope") == 0) x = O_SLOPE;
     return x;
Index: vector/v.to.db/report.c
RCS file: /grassrepository/grass6/vector/v.to.db/report.c,v
retrieving revision 1.11
diff -u -r1.11 report.c
--- vector/v.to.db/report.c 9 Feb 2006 03:09:07 -0000 1.11
+++ vector/v.to.db/report.c 7 Dec 2006 16:21:18 -0000
@@ -66,6 +66,13 @@
     for ( i = 0; i < vstat.rcat; i++ )
         fprintf (stdout, "%d|%.15g\n", Values[i].cat, Values[i].d1);
+ break;
+ case O_SLOPE:
+ fprintf (stdout,"cat|slope\n");
+ for ( i = 0; i < vstat.rcat; i++ )
+ fprintf (stdout, "%d|%.15g\n", Values[i].cat, Values[i].d1);
             break;
         case O_COOR:
Index: vector/v.to.db/update.c
RCS file: /grassrepository/grass6/vector/v.to.db/update.c,v
retrieving revision 1.17
diff -u -r1.17 update.c
--- vector/v.to.db/update.c 9 Feb 2006 03:09:07 -0000 1.17
+++ vector/v.to.db/update.c 7 Dec 2006 16:21:18 -0000
@@ -49,6 +49,7 @@
   case O_QUERY:
   case O_COMPACT:
   case O_PERIMETER:
+ case O_SLOPE:
       sprintf (buf1, "update %s set %s =", Fi->table, options.col[0]);
             break;
         case O_COOR:
@@ -79,6 +80,7 @@
       case O_AREA:
       case O_COMPACT:
       case O_PERIMETER:
+ case O_SLOPE:
         sprintf (buf2, "%s %f where %s = %d", buf1, Values[i].d1, Fi->key, Values[i].cat);
           break;
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
On Mon, Dec 11, 2006 at 06:53:57PM +0100, Jachym Cepicky wrote:
hi,
option "slope" now
hi jachym,
does it now work for LatLong? I guess I overlooked some email.
hi Markus,
> hi,
> option "slope" now
hi jachym,
yes, I was writing about this:
Jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
Hello Jachym
Just a little comment below:
hi,
option "slope" now
hi jachym,
I (maybe others) interpreted this as you admitting that the patch was not yet ready/good enough to commit to CVS! So maybe that's why nobody complained - Is it true that wrong results will be given in a lat/long location with no warning? If so, then something should be changed.
If not, and I've misunderstood, then it's all OK!
Paul
On Mon, Dec 11, 2006 at 07:05:01PM +0100, Jachym Cepicky wrote:
hi Markus,
> > hi,
> > option "slope" now
> hi jachym,
> Markus
Hi Jachym,
I don't think that we should knowingly introduce bugs in
GRASS. It would be good to get that resolved soon.
As Paul said - I also assumed that you would consider the
patch as non-ready, so I didn't further comment.
Best,
> > > option "slope" now
In fact it works with length:
GRASS 6.3.cvs (latlong):~ > v.to.db -p polbnda_italy_state op=length un=k col=dummy type=boundary
cat|length
-1|8630.5217187381
1|0
2 categories read from map
0 records selected from table
0 categories read from map exist in selection from table
0 categories read from map don't exist in selection from table
0 records updated/inserted
0 update/insert errors
We fixed that one year ago:
2005-11-30 16:26 markus
        * areas.c, description.html: Wolf Bergenheim: use geodetic length
        for perimeter in LatLong; prettified areas.c with indent
to verify exactly the coastline length for Italy which is given incorrectly in
the ASPRS Grid & datums paper on Italy.
Hi Jachym,
Best,
> because of
> ends up with G_calloc error: could not allocat memory.
Paul:
changed. If not, and I've misunderstood, then it's all OK!
a simple
if ((G_projection() == PROJECTION_LL))
   G_fatal_error("slope option not supported for lat/lon locations");
could allow the patch to go in without introducing bugs.
Of course we should try and fix the bug instead of coding around it,
and now is the time to do that.
Hamish
incorrectly in the ASPRS Grid & datums paper on Italy.
to be pedantic:
coastline length is a classic fractal problem with no real answer.
the best you can do is assume the dataset was digitized with the same
fractal depth throughout (and that's a bad assumption) and then compare
relative sections of the vector as a ratio.
"The empirical evidence suggests a rule which, if extrapolated, shows
that the measured length increases without limit as the measurement
scale decreases towards zero."
http://en.wikipedia.org/wiki/How_Long_Is_the_Coast_of_Britain%3F_Statistical_Self-Similarity_and_Fractional_Dimension
or did you get different answers from the same dataset, reprojected?
Hamish
to be pedantic:
I am aware of this fractal problem but that was not the point.
One year ago the module reported a few *degree* as length
for a boundary which was nonsense for the user. Now it calculated
the geodetic length of the vector pieces.
PS: http://grass.itc.it/pipermail/grass-dev/2005-November/020030.html
    http://grass.itc.it/pipermail/grass-dev/2005-November/020099.html
    http://grass.itc.it/pipermail/grass-dev/2005-November/020160.html
    (then we solved it offlist)
hallo,
On Mon, Dec 11, 2006 at 07:01:21PM +0000, Paul Kelly wrote:
Hello Jachym
>>>hi,
>>>option "slope" now
>>hi jachym,
Paul
Slope is calculated with line lenght. Calculating line length on
lat/long location does not work either. This patch adds new funtionality
and (should) does not break old ones. I tryed this in GRASS 6.2 and
calculating line length on lat/long location does not work there too.
So, as I got mostly positive feedback and as I did not break any
funtionality, I commited the patch.
I also tryed to describe, why this does not work on lat/long locations.
Sorry, I was not able to find out, where exactly the problem is. I
guess, some variable is not initialized.
If I should not commit the patch, because of this all, I'm sorry and
will remove this patch from cvs.
I'll fill the bug tracker for the length issue.
Jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
hi,
ee, sorry, I was confused. It seems to, that option=length does not work
for vectors WITHOUT database connection.
When I tryed this on new vector, with connected database table,
everything seem to work fine:
v.digit -n line
v.drape in=line out=line3d rast=dem
v.to.db -p col=nothing map=line3d option=length
cat|length
1|4645.31351829853
v.to.db -p col=nothing map=line3d option=slope
cat|slope
1|-0.0559703879998248
d.what.rast
14:43:43.389044E 49:50:30.741694N
dmt in jachym, actual (530.000000)
14:39:59.979022E 49:51:15.627726N
dmt in jachym, actual (269.000000)
echo "(269-530)/4645.313518"|bc -l
-.056185
So I would say, that calculating slope works
Jachym
> > > > option "slope" now
cat|length
-1|8630.5217187381
1|0
> Hi Jachym,
> Best,
> Markus
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
