[GRASS-dev] v.what.rast in a python script causes "grass.exceptions.CalledModuleError"
hi,
I've a addon script:
http://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.habitat.dem
which calls v.what.rast
http://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py#L297
this gives following error:
Upload DEM zonal statistics to the attribute table ...
Adding columns '['e_dem_minimum DOUBLE PRECISION', 'e_dem_maximum DOUBLE
PRECISION', 'e_dem_range DOUBLE PRECISION', 'e_dem_average DOUBLE
PRECISION', 'e_dem_median DOUBLE PRECISION']'
Adding column <e_dem_minimum> to the table
Adding column <e_dem_maximum> to the table
Adding column <e_dem_range> to the table
Adding column <e_dem_average> to the table
Adding column <e_dem_median> to the table
Processing data (240 categories)...
Updating the database ...
Statistics calculated from raster map <dembik> and uploaded to attribute
table of vector map <bik_hart_bruck_bioid>.
  File "C:\Users\myricaria\AppData\Roaming\GRASS7\addons/scr
ipts/v.habitat.dem.py", line 534, in <module>
    sys.exit(main())
ipts/v.habitat.dem.py", line 304, in main
    method = 'minimum,maximum,range,average,median')
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\python\grass
\script\core.py", line 373, in run_command
    return handle_errors(returncode, returncode, args,
kwargs)
\script\core.py", line 308, in handle_errors
    returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['v.rast.stats', '-c', 'map=bik_hart_bruck_bioid',
'layer=1', 'column_prefix=e_dem',
'method=minimum,maximum,range,average,median',
'raster=dembik'] ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
the columns in the attribute table are correctly be filled by the stats
data.
any idea the error?
thanks
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-what-rast-in-a-python-script-causes-grass-exceptions-CalledModuleError-tp5175682.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
attached a script with only the v.rast.stat part for a quick test
v.py <http://osgeo-org.1560.x6.nabble.com/file/n5175687/v.py&gt;
it fails also.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-what-rast-in-a-python-script-causes-grass-exceptions-CalledModuleError-tp5175682p5175687.html
it fails also.
Thanks for finding this, we were adjusting the scripts to the new python
error handling and we made a mistake in errorcode, fixed in r63302 and
backported.
Anna
best regards
Helmut
grass-dev mailing list
grass-dev@lists.osgeo.org
error handling and we made a >mistake in errorcode, fixed in r63302 and
backported.
thanks for the fix.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-what-rast-in-a-python-script-causes-grass-exceptions-CalledModuleError-tp5175682p5175845.html
