On Wed, Nov 5, 2014 at 3:32 AM, Markus Metz <markus.metz.giswork@gmail.com>
wrote:
On Mon, Nov 3, 2014 at 4:53 PM, Anna Petrášová <kratochanna@gmail.com>
wrote:
> On Mon, Nov 3, 2014 at 9:18 AM, Vaclav Petras <wenzeslaus@gmail.com>
wrote:
>> It seems that v.what's test_vwhat_layers test file is randomly failing
>> time to time with "ERROR: Unable to start driver <(null)>".
> It looks like db connection is not set at all. I added calling
db.connect -c
> to the test. However, I am not sure, is this how it is supposed to work?
> Almost no db module initializes db when not set.
The GRASS start-up script initializes db with db.connect -c when not set:
https://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py#L1435
therefore this problem does not occur if you start GRASS with grass.py
Testing script is using init() function from grass.script.setup, so
should be `db.connect -c` there?
http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/gunittest/multirunner.py#L95
Regarding v.what's test_vwhat_layers test, the error is correct
because db.tables lists tables in the given database using the
specified driver. It is an error if either database or driver are not
specified for db.tables.
This makes sense, perhaps the error message could be more informative in
case of db driver being NULL (or whatever is the value in C) so that you
can get something like:
ERROR: Unable to start driver because it is set to NULL. Was database
connected using db.connect?
What do you think?
Vaclav
Markus M
> I ran into the same problem
> when a shapefile is imported during creating new location.
> Anna
>> ERROR: setUpClass (__main__.TestMultiLayerMap)
>> Traceback (most recent call last):
>> File "vector/v.what/testsuite/test_vwhat_layers.py", line 121, in
>> setUpClass
>> cls.runModule('db.in.ogr', dsn='./data/table1.csv', output='t1')
>> File "etc/python/grass/gunittest/case.py", line 953, in runModule
>> errors=errors)
>> CalledModuleError: Module run 1 db.in.ogr ended with error
>> Process ended with non-zero return code
db.in_ogr(dsn='./data/table1.csv',
>> output='t1'). See the following errors:
>> File "scripts/db.in.ogr", line 127, in <module>
>> main()
>> File "scripts/db.in.ogr", line 76, in main
>> s = grass.read_command('db.tables', flags = 'p')
>> File "etc/python/grass/script/core.py", line 420, in read_command
>> returncode=returncode)
>> grass.exceptions.CalledModuleError: Module run None db.tables -p ended
>> with error
>> Process ended with non-zero return code 1. See errors in the (error)
>> output.
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-11-02-08-00/report_for_nc_spm_08_grass7_nc/vector/v.what/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-11-03-08-00/report_for_nc_spm_08_grass7_nc/vector/v.what/test_vwhat_layers/index.html
>> _______________________________________________
>> grass-dev mailing list
>> grass-dev@lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
