Dear all,
I’m adding some new material to the grass-promo repository [1]. I can also share some of the designs through Sticker Mule, too, so ask me if you want some.
I took the opportunity and added a trivial readme file which may clarify when to add things to it (that is any time). While with free online repo hosting services, the repo is not necessary for sharing, it is still a good place for potentially reusable artwork and other resources.
Finally, I have merge/write access, but can I get admin access to rename master to main and enable “squash and merge” only?
Best,
Vaclav
[1] https://github.com/OSGeo/grass-promo
On Thu, Oct 27, 2022 at 5:32 AM Vaclav Petras <wenzeslaus@gmail.com> wrote:
Dear all,
I'm adding some new material to the grass-promo repository [1]. I can also share some of the designs through Sticker Mule, too, so ask me if you want some.
That's cool stuff, thanks!
(and I have already seen it in the wild, it looks really good
Finally, I have merge/write access, but can I get admin access to rename master to main and enable "squash and merge" only?
I have now added the 'grass-admin' group (at time you, Martin Landa,
me) to the repo. For whatever reason it was missing.
You may now update the repo settings directly.
Best,
Best,
Vaclav
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
That’s cool stuff, thanks!
Thanks.
It’s worth emphasizing that sharing the designs through Sticker Mule is easy and the designs skip proofing phase as long it is exactly the same physical thing and you want to use Sticker Mule.
The repo is good when you want to modify the designs, use them on something else, or use a different provider.
I have now added the ‘grass-admin’ group (at time you, Martin Landa,
me) to the repo.
Thank you. Here is what I did:
master renamed to main
squash and merge is the only option
has readme
has social preview image (a quickly created file, updated in grass, added to grass-addons, website)
only up to 2 branches and tags can be updated in one push (also for grass, grass-addons, website)
Best,
Vaclav
