[GRASS-dev] vectors invisible if has layer2 but no layer1
I have noticed that if I have a vector that has categories in layer 2
and no cats in layer 1, d.vect by default doesn't display any of the
features, unless I specify layer=2 explicitely.
Try this - create a vector 'map' without categories in any layer.
Display it - you see it, OK. Now add categories into layer 2 only:
v.category in=map out=map_addcat_l2 option=add layer=2
d.erase
d.vect map_addcat_l2
You see nothing. No good. Could that be fixed?
Maciek
d.erase
I'm not sure it is a bug,
d.vect --help
Parameters:
        layer Layer number. If -1, all layers are displayed.
               default: 1
seems clear to me.
are you asking that "-1" be the default?
Hamish
d.erase
d.vect --help
Parameters:
               default: 1
seems clear to me.
Hmm, would make sense. Why should layer 1 be prefered? "All layers are
equal, but some are more equal than the other" ;)?
Maciek
d.erase
d.vect --help
Parameters:
               default: 1
seems clear to me.
I would vote against that: I think that layers are already complicated to understand, and are mostly used by power users who can use layer=-1 when they know what they are doing. Making this the default would be the road to even more potential confusion IMHO.
Moritz
