[GRASS-dev] WinGRASS-6.3.0RC6 & Python GUI
I reinstalled Python (2.5.2) + Python Extensions for Windows (Build 210 - py2.5) + WxPython (2.8.7.1 - unicode - py25) but I still have the same errror (follows):
http://www.webalice.it/marco.pasetti/temp/grass_bugs/bug002.png
Then, after pressing ok button, reports as follows in MSYS console:
Marco@NOTEBOOKMARCO /usr/local/bin
$ grass63 -wxpython
Cleaning up temporary files…
Starting GRASS …
WARNING: Attention!
WARNING: Locking is not supported on Windows!
GRASS GUI should be wxpython
/ / __ / | / / / / __/ / /
/ / __/ /
/ / /| | _
\ / / __ / / _
/ / , / ___ |
_
// _///_/
Welcome to GRASS 6.3.0RC6 (2008)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bourne Shell (/bin/sh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.3.0RC6 (SIT-Lombardia):C:/MSYS/local/bin >
profile.py:
This module requires the NumPy module,
which could not be imported. It probably is not installed
(it’s not part of the standard Python distribution). See the
Numeric Python site (http://numpy.scipy.org) for information on
downloading source or binaries.
File “C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py”, line 1358, in
sys.exit(main())
File “C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py”, line 1351, in main
app = GMApp(workspaceFile)
File “C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py”, line 1273, in init
wx.App.init(self, False)
File “C:\DevTools\Python\Lib\site-packages\wx-2.8-msw-unicode\wx_core.py”, line 7836, in init
self._BootstrapApp()
File “C:\DevTools\Python\Lib\site-packages\wx-2.8-msw-unicode\wx_core.py”, line 7433, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py”, line 1289, in OnInit
workspace = self.workspaceFile)
File “C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py”, line 158, in init
self.NewDisplay(show=False)
File “C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py”, line 1025, in NewDisplay
auimgr=self._auimgr, showMapDisplay=show)
File “C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\wxgui_utils.py”, line 76, in init
self.Map = render.Map() # instance of render.Map to be associated with display
File “C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\render.py”, line 210, in init
self.InitRegion()
File “C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\render.py”, line 244, in InitRegion
self.SetRegion()
File “C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\render.py”, line 462, in SetRegion
self.region = self.__adjustRegion()
File “C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\render.py”, line 296, in __adjustRegion
mapwidth = abs(self.region[“e”] - self.region[“w”])
KeyError: ‘e’
Martin, I really don’t know why it works for you and not for me! There’s something frustrating in that, because you followed the guide I wrote… and that I, obviously, followed too!
Marco
Markus,
actually… NO!
I read the alert in the error lines, but I thought that it was a part of wxpython install, and that, in some way, I didn’t found it because of internal errors! all that because python-NumPy is not included in python GUI requirements
so, I’ll install it and retry :wink:
please patch http://svn.osgeo.org/grass/grass/trunk/gui/wxpython/README and add info about it.
Thanks
Marco
Da: neteler.osgeo@gmail.com per conto di Markus Neteler
Inviato: gio 27/03/2008 10.16
A: marco.pasetti@alice.it
Oggetto: Re: [GRASS-dev] WinGRASS-6.3.0RC6 & Python GUI
Ciao Marco,
do you actually have python-NumPy installed?
That’s needed…
ciao
markus
On Thu, Mar 27, 2008 at 10:10 AM, marco.pasetti@alice.it wrote:
errror (follows):
$ grass63 -wxpython
Starting GRASS …
WARNING: Attention!
/ / __/ /
/ / /| | _
\ / / __ / / _
/ / , / ___ |
_
// _///_/
profile.py:
sys.exit(main())
main
init
File
7836, in init
File
OnInit
init
NewDisplay
File
76, in init
with display
line 210, in init
self.InitRegion()
self.SetRegion()
KeyError: ‘e’
Marco
grass-dev mailing list
grass-dev@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
I installed NumPy, but it solved only the first item in the error list; I have the same error screenshot (Execution Failed: ‘g.region.exe -u -g -p -c’) and then
sys.exit(main())
self.InitRegion()
self.SetRegion()
KeyError: ‘e’
Marco
Da: grass-dev-bounces@lists.osgeo.org per conto di marco.pasetti@alice.it
Inviato: gio 27/03/2008 10.29
A: grass-dev@lists.osgeo.org
Oggetto: R: [GRASS-dev] WinGRASS-6.3.0RC6 & Python GUI
Markus,
actually… NO!
Thanks
Marco
Ciao Marco,
That’s needed…
ciao
markus
errror (follows):
$ grass63 -wxpython
Starting GRASS …
WARNING: Attention!
/ / __/ /
/ / /| | _
\ / / __ / / _
/ / , / ___ |
_
// _///_/
profile.py:
sys.exit(main())
main
init
File
7836, in init
File
OnInit
init
NewDisplay
File
76, in init
with display
line 210, in init
self.InitRegion()
self.SetRegion()
KeyError: ‘e’
Marco
Hi Marco,
2008/3/27, marco.pasetti@alice.it <marco.pasetti@alice.it>:
[snip]
> $ grass63 -wxpython
> Cleaning up temporary files.....
> Starting GRASS ...
> WARNING: Attention!
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> GRASS homepage:
> profile.py:
> (it's not part of the standard Python distribution). See the
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 1358, in
> <module>
> sys.exit(main())
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 1351, in
> main
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 1273, in
> __init__
> wx.App.__init__(self, False)
> File
"C:\DevTools\Python\Lib\site-packages\wx-2.8-msw-unicode\wx\_core.py",
line
> 7836, in __init__
> File
line
> return _core_.PyApp__BootstrapApp(*args, **kwargs)
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 1289, in
> OnInit
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 158, in
> __init__
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 1025, in
> NewDisplay
> File
"C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\wxgui_utils.py",
line
> 76, in __init__
> with display
> File
"C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\render.py",
> line 210, in __init__
> self.InitRegion()
> File
> self.SetRegion()
> File
> File
> mapwidth = abs(self.region["e"] - self.region["w"])
> KeyError: 'e'
> Martin, I really don't know why it works for you and not for me! There's
> something frustrating in that, because you followed the guide I wrote...
and
I compiled RC6 on Windows now, I cannot reproduce this error. Seems to
work here.
Looking at
http://trac.osgeo.org/grass/browser/grass/tags/release_20080321_grass_6_3_0RC6/gui/wxpython/gui_modules/render.py#L221
self.region directory is initialized by
self.region = self.GetRegion()
Result: on my machine RC6 works (GNU/Linux and tested on Windows too)
Can anyone confirm it?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
My first guess is that it's related to GDAL, i.e. it can't find either
the GDAL DLL or one of the (many) DLLs which GDAL requires.
The Python error is a consequence of g.region failing. Essentially, if
g.region doesn't work, the GUI isn't going to work.
Hi Glynn,
How could that be if all works well with tcl/tk GUI?
I tried, and g.region works perfectly if I open GRASS with tcl/tk GUI.
Marco
-----Messaggio originale-----
Da: Glynn Clements [mailto:glynn@gclements.plus.com]
Inviato: giovedì 27 marzo 2008 22.24
Cc: grass-dev@lists.osgeo.org
My first guess is that it's related to GDAL, i.e. it can't find either the
The path, maybe? Windows uses %PATH% to locate DLLs.
Of course, there are other reasons why the call might fail, e.g. it
could be a problem with the gcmd code.
All needed paths have been added to %PATH% for grass63.bat and to $PATH for
grass63 (as I launch GRASS using grass63 -wxpython from MSYS console)
Marco
Inviato: venerdì 28 marzo 2008 1.11
A: Marco Pasetti
Oggetto: Re: R: [GRASS-dev] WinGRASS-6.3.0RC6 & Python GUI
Of course, there are other reasons why the call might fail, e.g. it could be
I'm afraid folks.. I'm a gigantic idiot!!!
I supposed to work with the *package version* that has all the dlls in an
unique folder, while I was launching grass from the *original* msys
environment, where pgsql.dll is placed in the specific pgsql/lib folder!!!
(Glynn, as usual you were right!!!)
Sorry!
Now the new python interface works, and it automatically starts even if I
don't specify -wxpython after grass63 command in shell.
I didn't have time to perform many tests, but opening existing locations it
seems to work; only two things:
1) when I exit it reports the following message in msys shell:
$ grass63
Starting GRASS ...
WARNING: Attention!
GRASS 6.3.0RC6 (SIT-Lombardia):C:/MSYS/local/bin > Traceback (most recent
call last):
  File "C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\mapdisp.py",
line 2412, in OnFocus
    self.layerbook.SetSelection(pgnum)
  File
"C:\DevTools\Python\Lib\site-packages\wx-2.8-msw-unicode\wx\lib\flatnotebook
.py", line 3275, in SetSelection
    if not self._pages.GetEnabled(page) and len(self._windows) > 1 and not
self._bForceSelection:
  File
"C:\DevTools\Python\Lib\site-packages\wx-2.8-msw-unicode\wx\_core.py", line
14318, in __getattr__
    raise PyDeadObjectError(self.attrStr % self._name)
wx._core.PyDeadObjectError: The C++ part of the PageContainer object has
been deleted, attribute access no longer allowed.
  File
  File
2) When I create a new location using epsg codes, next button is not enabled
since I don't press Browse codes, even if I already typed the desired code.
Then, I remember that when I created locations with epsg=3003, GRASS asked
me to select an option for towgs84 parameters; now GRASS asks me only for
"Datum Transformation" without showing descriptions for the options (and
narrows button don't work too, I need to enter the option manually)
Thanks and goodnight
Marco
2008/3/28, Marco Pasetti <marco.pasetti@alice.it>:
great:-)
$ grass63
Starting GRASS ...
WARNING: Attention!
call last):
  File
  File
  File
  File
yes, I know, some Windows-specific errors, I will try to fix it, but
not for 6.3.0.
Entered code is checked against currently loaded EPSG database, I
enabled loading default EPSG database file (on entering the EPSG
wizard page), see
http://trac.osgeo.org/grass/changeset/30775
also backported to releasebranch_6_3 (for 6.3.0).
Martin
