hellik
August 11, 2019, 11:25am
1
trying to compile an uotodate winGRASS master, I get a lot of following
errors:
e.g.
make[4]: Entering directory '/usr/src/grass_trunk_git/grass/lib/pngdriver'
if [ "" != "" ] ; then
GISRC=/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/demolocation/.grassrc79
GISBASE=C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32
PATH="/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/scripts:$PATH"
PYTHONPATH="C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python;C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/gui/wxpython;$PYTHONPATH"
PATH="/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/scripts:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/lib:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/lib:/c/OSGeo4W64/apps/Python37:/usr/bin:/mingw64/bin/:/c/OSGeo4W64/bin:/usr/src/grass_trunk_git/grass/mswindows/osgeo4w/lib:/usr/src/grass_trunk_git/grass/mswindows/osgeo4w"
LC_ALL=C LANG=C LANGUAGE=C --html-description < /dev/null | grep -v
'</body>\|</html>' > pngdriver.tmp.html ; fi
VERSION_NUMBER=7.9.dev VERSION_DATE=2019 MODULE_TOPDIR=../.. \
python3
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/tools/mkhtml.py
pngdriver >
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/docs/html/pngdriver.html
Fatal Python error: initfsencoding: unable to load the file system codec
ModuleNotFoundError: No module named 'encodings'
make[4]: Entering directory '/usr/src/grass_trunk_git/grass/lib/psdriver'
'</body>\|</html>' > psdriver.tmp.html ; fi
python3
psdriver >
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/docs/html/psdriver.html
it seems following python error:
any idea?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
hellik
August 11, 2019, 11:50am
2
errors:
e.g.
</body>
</html>
python3
pngdriver >
</body>
</html>
python3
psdriver >
any idea?
it seems to be some PATH issue according to e.g.
https://bugs.python.org/issue27054
https://stackoverflow.com/questions/42512817/fatal-python-error-on-windows-10-modulenotfounderror-no-module-named-encodings?rq=1
https://vi.stackexchange.com/questions/16216/fatal-python-error-py-initialize-unable-to-load-the-file-system-codec-importer?rq=1
hkmyr@DESKTOP-VADT8Q4 MINGW64 /usr/src/grass_trunk_git/grass
$ python
Python 3.7.4 (default, Jul 30 2019, 07:31:04) [GCC 9.1.0 64 bit (AMD64)] on
win32
Type "help", "copyright", "credits" or "license" for more information.
import sys
sys.path
['', 'C:/msys64/mingw64/lib/python37.zip',
'C:/msys64/mingw64/lib/python3.7', 'C:/msys64/mingw64/bin',
'C:/msys64/mingw64/lib/python3.7/lib-dynload',
'C:/msys64/mingw64/lib/python3.7/site-packages']
have to investigate ...
best regards
Helmut
