[GRASS-dev] WinGRASS: Xerces-C and Expat under MingW
Dear WinGRASS friends,
I just got hold of my old MinGW notes and would like
to contribute a bit to the GRASS Win binaries.
Has anyone got GDAL 1.5.0 to configure and compile correctly
*including* support for Xerces-C 2.8.0 on MinGW?
I have tried both DLL binaries and compilation from scratch
(which only creates static libs at the moment, but that's OK).
Now, the GDAL configure scripts tries to compile a small Xerces-C
test program and keeps failing like this:
C:/DOCUME~1/bart/LOCALS~1/Temp/cck1aaaa.o: In function
`ZN11xercesc_2_810XMLDeleterD1Ev':
C:/msys/1.0/local/include/xercesc/util/PlatformUtils.hpp:851: undefined
reference to `xercesc_2_8::XMLUni::fgXercescDefaultLocale'
reference to `xercesc_2_8::XMLPlatformUtils::Initialize(char const*, char
const*, xercesc_2_8::PanicHandler*, xercesc_2_8::MemoryManager*, bool)'
collect2: ld returned 1 exit status
The crazy thing is that I know the libraries are fine and
I grepped for "" in the binaries and found the declaration for
the symbol "fgXercescDefaultLocale" in there!
(although it is not present in the "xercesc_2_8::XMLUni::" namespace
form, but I don't know whether it should be).
Also, I had Xerces-C as a static lib in the past and GDAL
would find and use it just fine. That was GDAL 1.4.4, though, so maybe
they just recently added that critical test program.
There are similar problems with Expat. I can also not get
GDAL 1.5 to recognize it.
Any help would be greatly appreciated. It seems that Xerces-C would
be important for WMS support in GDAL.
Best,
Benjamin
Hi Benjamin,
for xerces I cannot help, while about expat I did a lot of attempts. GDAL configure doesn’t want to find it, and I don’t know why!!!
I think that you would waste your time; it’s better to concentrate strengths on xerces
Marco
Da: grass-dev-bounces@lists.osgeo.org per conto di benjamin.ducke@ufg.uni-kiel.de
Inviato: lun 03/03/2008 15.18
A: grass-dev@lists.osgeo.org
Oggetto: [GRASS-dev] WinGRASS: Xerces-C and Expat under MingW
including support for Xerces-C 2.8.0 on MinGW?
(which only creates static libs at the moment, but that’s OK).
ZN11xercesc_2_810XMLDeleterD1Ev': C:/msys/1.0/local/include/xercesc/util/PlatformUtils.hpp:851: undefined reference to xercesc_2_8::XMLUni::fgXercescDefaultLocale’
const*, xercesc_2_8::PanicHandler*, xercesc_2_8::MemoryManager*, bool)’
I grepped for “” in the binaries and found the declaration for
the symbol “fgXercescDefaultLocale” in there!
(although it is not present in the “xercesc_2_8::XMLUni::” namespace
form, but I don’t know whether it should be).
Best,
Benjamin
grass-dev mailing list
