[GRASS-dev] WinGrass7-installer + "GRASS 7.0.SVN with MSYS"-desktop-shortcut
hi,
with the last modifications of the WinGrass7 and WinGrass7-installer, Grass7 is started by the grass70.py script.
if you start with the "GRASS-70-SVN"-desktop-shortcut, you get WinGrass7 starting AND in the background a full functional windows-console.
in this windows-console you can start - if you want within a Grass7-session - python or a shell (in this shell you have access to sed, awk, ...) and can use also all windows-commandline-tools.
the "GRASS 7.0.SVN with MSYS"-desktop-shortcut is broken at the moment.
so I would opt for deleting the "GRASS 7.0.SVN with MSYS"-desktop-shortcut, because a full functional commandline is available (see above).
and the docs should be adapted for this.
any opinion?
best regards
Helmut
___________________________________________________________
NEU: WEB.DE DSL für 19,99 EUR/mtl. und ohne Mindest-Laufzeit!
http://produkte.web.de/go/02/
2010/4/9 Helmut Kudrnovsky <hellik@web.de>:
I would rather vote for fixing starting script to enable start with
MSYS, not just removing this option.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Hi
Von: Martin Landa
Gesendet: 13.06.2010 15:16:04
An: Helmut Kudrnovsky
Betreff: Re: [GRASS-dev] WinGrass7-installer + "GRASS 7.0.SVN with MSYS"-desktop-shortcut
Martin
at the moment by the WinGrass7-installer there are installed following files C:\Program Files\GRASS-70-SVN:
- grass70.bat:
"rem *******Environment variables***********
rem Set GRASS Installation Directory Variable
set GISBASE=C:\Program Files\GRASS-70-SVN
rem Directory where your .grass7/rc file will be stored
set HOME=%USERPROFILE%
rem Name of the wish (Tk) executable
set GRASS_WISH=wish.exe
rem Path to the shell command
set GRASS_SH=%GISBASE%\msys\bin\sh.exe
rem Set Path to utilities (libraries and bynaries) used by GRASS
set PATH=%GISBASE%\msys\bin;%PATH%
set PATH=%GISBASE%\extrabin;%GISBASE%\extralib;%PATH%
set PATH=%GISBASE%\tcl-tk\bin;%GISBASE%\sqlite\bin;%GISBASE%\gpsbabel;%PATH%
rem Set Path to default web browser
set GRASS_HTML_BROWSER=explorer
rem Path to the proj files (notably the epsg projection list)
set GRASS_PROJSHARE=%GISBASE%\proj
rem Path to the python directory
set PYTHONHOME=%GISBASE%\Python25
if "x%GRASS_PYTHON%" == "x" set GRASS_PYTHON=python
%GRASS_PYTHON% "%GISBASE%\grass70.py" %*"
- grass70.sh:
"trap "echo 'User break!' ; exit" 2 3 9 15
# Set the GISBASE variable
GISBASE="/C/Program Files/GRASS-70-SVN"
export GISBASE
# Set the PATH variable
PATH="$GISBASE/extrabin:$GISBASE/extralib:$PATH"
PATH="$GISBASE/tcl-tk/bin:$GISBASE/sqlite/bin:$GISBASE/gpsbabel:$PATH"
export PATH
# Set the PYTHONPATH variable
PYTHONPATH="$GISBASE/etc/python:$GISBASE/Python25:$PYTHONPATH"
export PYTHONPATH
PYTHONHOME="C:\Program Files\GRASS-70-SVN\Python25"
export PYTHONHOME
if [ -z "$GRASS_PYTHON" ] ; then
GRASS_PYTHON=python
export GRASS_PYTHON
fi
# Set the GRASS_PROJSHARE variable
GRASS_PROJSHARE="C:\Program Files\GRASS-70-SVN\proj"
export GRASS_PROJSHARE
"$GRASS_PYTHON $GISBASE/grass70.py" "$@"
and grass70.py
the desktop-shortcut to start WinGrass7 with Msys is actuallay following:
"C:\Program Files\GRASS-70-SVN\msys\msys.bat" "/grass/bin/grass70 -wxpython"
(http://trac.osgeo.org/grass/browser/grass/trunk/mswindows/GRASS-Installer.nsi#L624)
I've tried a little different approaches to launch WinGrass7 with a msys-command-line , but no success at
the moment.
maybe any hints?
Helmut
WEB.DE DSL ab 19,99 Euro/Monat. Bis zu 150,- Euro Startguthaben und
50,- Euro Geldprämie inklusive! https://freundschaftswerbung.web.de
the moment.
maybe any hints?
Create a batch file which sets SHELL to the full Windows path to MSys'
sh.exe then runs grass70.py.
hi,
Von: Glynn Clements
Gesendet: 14.06.2010 18:01:27
>the moment.
maybe any hints?
now I'm a little bit confused, because the installed C:\Program Files\GRASS-70-SVN\grass70.bat already
does this:
in my original post (http://lists.osgeo.org/pipermail/grass-dev/2010-April/049998.html):
"in this windows-console you can start - if you want within a Grass7-session - python or a shell
(in this shell you have access to sed, awk, ...) and can use also all windows-commandline-tools."
so therefore I've suggested to remove the "WinGrass7 with msys-shortcut" because there is already a shell accessible.
best regards
Helmut
> >the moment.
>> maybe any hints?
does this:
That doesn't set SHELL, which is what grass70.py uses to decide which
shell to run.
GRASS_SH is the program used for running shell scripts.
There should be separate shortcuts for running GRASS with cmd.exe and
with sh.exe.
