Hello all,
My code is working fine in Linux, but I run into a (related?) problem
running in Windows.
Running from the Anaconda shell:
File "e:\itzi\gis.py", line 24, in <module>
import grass.temporal as tgis
File "C:\OSGEO4~1\apps\grass\grass-7.0.5\etc\python\grass\temporal\__init__.py",
line 1, in <module>
from core import *
File "C:\OSGEO4~1\apps\grass\grass-7.0.5\etc\python\grass\temporal\core.py",
line 38, in <module>
from c_libraries_interface import *
File "C:\OSGEO4~1\apps\grass\grass-7.0.5\etc\python\grass\temporal\c_libraries_interface.py",
line 19, in <module>
import grass.lib.gis as libgis
File "C:\OSGEO4~1\apps\grass\grass-7.0.5\etc\python\grass\lib\gis.py",
line 23, in <module>
_libs["grass_gis.7.0.5"] = load_library("grass_gis.7.0.5")
File "C:\OSGEO4~1\apps\grass\grass-7.0.5\etc\python\grass\lib\ctypes_loader.py",
line 55, in load_library
return self.load(path)
line 221, in load
return _WindowsLibrary(path)
line 207, in __init__
self.cdll = ctypes.cdll.LoadLibrary(path)
File "C:\Users\lcourty\Anaconda2\lib\ctypes\__init__.py", line 440,
in LoadLibrary
return self._dlltype(name)
File "C:\Users\lcourty\Anaconda2\lib\ctypes\__init__.py", line 362,
in __init__
self._handle = _dlopen(self._name, mode)
WindowsError: [Error 126] The specified module could not be found
This is using the OSGeo4W version. If using the WinGRASS binary, the
code fail at the same place but without any traceback.
From the GRASS shell, it fail earlier:
File "C:\Users\lcourty\Anaconda2\Scripts\itzi-script.py", line 5, in <module>
from pkg_resources import load_entry_point
ImportError: No module named pkg_resources
I have the feeling that it could be related to the fact that Anaconda
and GRASS use their own version of Python. But I'm not sure and I
don't know how to fix that.
Any clue?
Laurent
2016-10-05 8:20 GMT-05:00 Laurent C. <lrntct@gmail.com>:
Hi Sören,
Thanks for your answer. I did something similar and it works well under
Linux.
Making those hacks works with Windows seems to be a bit more complex,
though.
Laurent
2016-09-24 4:35 GMT-05:00 Sören Gebbert <soerengebbert@googlemail.com>:
Hi Laurent,
i have attached a Python script that shows the handling of tgis.init() in
a
subprocess in case location and mapsets change using grass72.
The following output was generated with this script, it seems to work on
my
system:
soeren@knecht:~$ python test_tgis.py
New envrionment: {u'MAPSET': u'PERMANENT', u'GISDBASE':
u'/home/soeren/grassdata', u'LOCATION_NAME': u'nc_spm_08_grass7'}
TGIS init:
database: /home/soeren/grassdata
mapset: PERMANENT
New envrionment: {u'MAPSET': u'user1', u'GISDBASE':
TGIS init:
mapset: user1
u'/home/soeren/grassdata', u'LOCATION_NAME': u'nc_spm_08'}
TGIS init:
mapset: PERMANENT
TGIS init:
mapset: user1
Best regards
Soeren
2016-09-24 5:32 GMT+02:00 Laurent C. <lrntct@gmail.com>:
Hi Sören,
I followed you suggestion and now each simulation run in its own process
using the multiprocessing library. It works well, thanks.
However, there was indeed something strange going on:
The new mapset, location and accessible mapsets were set properly, as
seen
by the output of g.mapset and g.mapsets
However, the output of ciface.available_mapsets() and therefore
core.get_available_temporal_mapsets() were not updated after the first
simulation, so tgis.init() were failing, not seeing the new current
mapset
in its own list of available mapsets.
Below was the output of the software:
g.mapset -p
swashes_1d_1000m
g.mapsets -p
Accessible mapsets:
swashes_1d_1000m PERMANENT
['swashes_1d_1000m', 'PERMANENT']
{'swashes_1d_1000m': ('sqlite',
'/home/laurent/grassdata/flood_test/swashes_1d_1000m/tgis/sqlite.db')}
Starting simulation for configuration file macdo1000.ini...
g.mapset -p
hull
g.mapsets -p
Accessible mapsets:
hull PERMANENT hull_rain
ERROR: Unable to execute sql statement. There is no temporal database
connection defined for mapset <hull>
It seems that tgis.init() is not doing what it is supposed to, according
to the documentation:
"Re-run this function in case the following GRASS variables change while
the process runs:
- MAPSET
- LOCATION_NAME
- GISDBASE
- TGIS_DISABLE_MAPSET_CHECK
- TGIS_DISABLE_TIMESTAMP_WRITE
Thanks again.
Laurent
2016-09-22 13:52 GMT-05:00 Sören Gebbert <soerengebbert@googlemail.com>:
> Hi Laurent,
> the temporal framework was neither tested nor designed to work in a
> script
> that changes the location while running. I would suggest to run the
> temporal
> framework related code in a subprocess that is created each time the
> location or mapset changes. Unfortunately i have no other suggestion.
> However, have you tested your code with grass 7.2 or 7.3? Many
> improvements
> have been implement in the recent version that would be beneficial to
> use.
> Best regards
> Soeren
> 2016-09-22 2:47 GMT+02:00 Laurent C. <lrntct@gmail.com>:
>> Hello all,
>> I've ran into another related issue.
>> One of the goal of running the software outside of GRASS shell is to
>> batch process simulations in various Locations/mapsets.
>> I set the GRASS session for each case. The simulation works well for
>> the first case.
>> However when starting the second case, tgis.init() fails with the
>> following error:
>> The mapset and location are properly set.
>> If this case is run first, it works well and it's the second one that
>> fail.
>> Running t.connect -c between two cases does not solve the problem.
>> Actually, t.connect -p shows the correct connection parameters, but
>> tgis.init() still fails.
>> Regards,
>> Laurent
>> 2016-09-21 18:27 GMT-05:00 Laurent C. <lrntct@gmail.com>:
>> > Hi Sören,
>> > Setting LD_LIBRARY_PATH is working, thanks. But it cannot be set at
>> > run-time, which is not very user-friendly.
>> > I guess this issue is related to the ticket 2424 [1].
>> > I managed to get it work at run-time by restarting the program with
>> > sys.execv() after setting the path [2], but I find it a bit ugly and
>> > quite verbose to be multi-platform.
>> > It would be great if an easier option was possible.
>> > Regards,
>> > Laurent
>> > [1] https://trac.osgeo.org/grass/ticket/2424
>> > [2]
>> > http://stackoverflow.com/questions/6543847/setting-ld-library-path-from-inside-python
>> > 2016-09-21 15:40 GMT-05:00 Sören Gebbert
>> >> Hi,
>> >> i think you have to put the GRASS libraries into your
>> >> LD_LIBRARY_PATH
>> >> so
>> >> that the python wrapper can access them.
>> >> Best regards
>> >> Soeren
>> >> 2016-09-21 20:37 GMT+02:00 Laurent C. <lrntct@gmail.com>:
>> >>> Hello all,
>> >>> I'm trying to adapt a python module in order for it to be run
>> >>> outside
>> >>> of
>> >>> GRASS.
>> >>> I followed the instructions from the wiki and
>> >>> lib/python/script/setup.py
>> >>> gsetup.init() run without error and I can list maps like in the
>> >>> example.
>> >>> However, when I try to import the temporal module, I receive this
>> >>> error:
>> >>> File "/usr/lib/grass70/etc/python/grass/temporal/__init__.py",
>> >>> line
>> >>> 1, in <module>
>> >>> from core import *
>> >>> File "/usr/lib/grass70/etc/python/grass/temporal/core.py", line
>> >>> 38,
>> >>> in <module>
>> >>> File
>> >>> "/usr/lib/grass70/etc/python/grass/temporal/c_libraries_interface.py",
>> >>> File "/usr/lib/grass70/etc/python/grass/lib/gis.py", line 23, in
>> >>> <module>
>> >>> _libs["grass_gis.7.0.4"] = load_library("grass_gis.7.0.4")
>> >>> File "/usr/lib/grass70/etc/python/grass/lib/ctypes_loader.py",
>> >>> line
>> >>> 55, in load_library
>> >>> line
>> >>> 71, in load
>> >>> raise ImportError,e
>> >>> ImportError: libgrass_datetime.7.0.4.so: cannot open shared object
>> >>> file: No such file or directory
>> >>> Did I forgot to set-up something or this is a bug?
>> >>> Cheers,
>> >>> Laurent
>> >>> _______________________________________________
>> >>> grass-dev mailing list
>> >>> grass-dev@lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/grass-dev
