[GRASS-dev] wxGUI command line: " changed into @ while typing
I noticed on Linux that while type
v.extract input=lakes out=anything where=@
and a map name list pops up...
Is this happening to anyone else?
I use
GRASS version: 7.0.svn
GRASS SVN Revision: 58873M
Build Date: 2014-01-04
GDAL/OGR: 1.10.1
PROJ.4: 4.8.0
GEOS:
SQLite: 3.8.2
Python: 2.7.5
wxPython: 2.8.12.0
Platform: Linux-3.12.9-301.fc20.x86_64-x86_64-with-fedora-20-Heisenbug
(Un)related: on Windows this seems to work but retrieving the command
from the wxGUI history by scrolling "eats" the quotes.
thanks
On Mon, Feb 10, 2014 at 1:19 PM, Markus Neteler <neteler@osgeo.org> wrote:
If I understand correctly, you type " character but it is changed to @
character. This does not happen to me with EN and CS keyboard layouts.
GRASS SVN Revision: 58850M
Build Date: 2014-01-03
GDAL/OGR: 1.10.0
PROJ.4: 4.8.0
GEOS: 3.3.8
SQLite: 3.7.9
Python: 2.7.3
wxPython: 2.8.12.1
Platform: Linux-3.2.0-58-generic-pae-i686-with-Ubuntu-12.04-precise
I use
GDAL/OGR: 1.10.1
PROJ.4: 4.8.0
GEOS:
SQLite: 3.8.2
Python: 2.7.5
wxPython: 2.8.12.0
thanks
grass-dev mailing list
grass-dev@lists.osgeo.org
The " character is changed to @ for me too on a DE keyboard layout.
GDAL/OGR: 1.10.0
PROJ.4: 4.8.0
GEOS: 3.3.8
SQLite: 3.7.9
Python: 2.7.3
wxPython: 2.8.12.1
I use
GDAL/OGR: 1.10.1
PROJ.4: 4.8.0
GEOS:
SQLite: 3.8.2
Python: 2.7.5
wxPython: 2.8.12.0
thanks
On Mon, Feb 10, 2014 at 2:28 PM, Markus Metz
wrote:
>> Hi,
Could someone test the attached diff please?
Anna
> GDAL/OGR: 1.10.0
> PROJ.4: 4.8.0
> GEOS: 3.3.8
> SQLite: 3.7.9
> Python: 2.7.3
> wxPython: 2.8.12.1
>> I use
>> GDAL/OGR: 1.10.1
>> PROJ.4: 4.8.0
>> GEOS:
>> SQLite: 3.8.2
>> Python: 2.7.5
>> wxPython: 2.8.12.0
>> thanks
>> Markus
>> _______________________________________________
(attachments)
prompt.diff (3.97 KB)
On Mon, Feb 10, 2014 at 3:25 PM, Anna Petrášová <kratochanna@gmail.com>wrote:
On Mon, Feb 10, 2014 at 2:28 PM, Markus Metz <
wrote:
>> Hi,
Sorry, new better diff attached.
Anna
> GDAL/OGR: 1.10.0
> PROJ.4: 4.8.0
> GEOS: 3.3.8
> SQLite: 3.7.9
> Python: 2.7.3
> wxPython: 2.8.12.1
>> I use
>> GDAL/OGR: 1.10.1
>> PROJ.4: 4.8.0
>> GEOS:
>> SQLite: 3.8.2
>> Python: 2.7.5
>> wxPython: 2.8.12.0
>> thanks
>> Markus
(attachments)
prompt.diff (6.68 KB)
On Mon, Feb 10, 2014 at 10:49 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
> wrote:
>> Hi,
Locally applied, it helps and the " is "generated" as expected.
Only scrolling back and forth in the wxGUI cmd line history eats the "
up but that probably unrelated.
markusN
>>> > wrote:
>>> >> Hi,
layouts.
yes, that's unrelated, I remember I looked at it once, but I am not really
sure what was the problem...
The quotes issue is fixed in r58984 for GRASS 7 and backported
Anna
markusN
