[GRASS-dev] wxGUI doesn't start in newest GRASS 7 svn
Something changed in the past 24 hours so that the wxPython GUI won't start in GRASS 7 (trunk). Here is the error. I have to leave for a bit, but will also try to track it down if need be.
Last login: Mon Jul 21 19:04:12 on ttys001
cmb-MBP-2:~ cmbarton$ '/Applications/Grass/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Cleaning up temporary files ...
Starting GRASS ...
   File "/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/wxpython/gis_set.py", line 807, in <module>
     GRASSStartUp = StartUp(0)
   File "//Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 7836, in __init__
     self._BootstrapApp()
   File "//Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 7433, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
   File "/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/wxpython/gis_set.py", line 790, in OnInit
     StartUp = GRASSStartup()
   File "/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/wxpython/gis_set.py", line 48, in __init__
     self.grassrc = self._read_grassrc()
   File "/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/wxpython/gis_set.py", line 377, in _read_grassrc
     key, val = line.split(":", 1)
ValueError: need more than 1 value to unpack
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
Michael
Starting GRASS ...
This error is magically gone. I don't know where it came from or how I fixed it. I tried changing my .profile file and .bashrc files, but ended up with them as before. And all works OK.
Michael
