[GRASS-dev] wxGUI import chain
Is there any reason why gui/wxpython/gis_set.py imports (eventually)
etc/python/grass/pygrass/raster/buffer.py?
Anyway, r62196 fails to start the GUI in trunk because of broken
pygrass. I doubt if it is a good idea to make pygrass a dependency of
the GUI.
Markus M
On Mon, Oct 6, 2014 at 3:15 PM, Markus Metz <markus.metz.giswork@gmail.com>
Can you provide a traceback? I cannot reproduce.
the GUI.
Perhaps this is another motivation to separate modules from PyGRASS and
empty __init__.py files (#2424).
PyGRASS is currently (directly used) used in
gui/wxpython/gui_core/gselect.py:56: from grass.pygrass import messages
gui/wxpython/tplot/frame.py:44:from grass.pygrass.vector.geometry import
Point
gui/wxpython/tplot/frame.py:45:from grass.pygrass.raster import RasterRow
In tplot is probably can be imported on demand. I'm not sure about gselect,
maybe it relates to temporal framework. Temporal framework is used in the
GUI and is using PyGRASS.
Vaclav
http://trac.osgeo.org/grass/ticket/2424
Markus M
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Markus,
On Mon, Oct 6, 2014 at 9:15 PM, Markus Metz
the GUI.
I'm not able to reproduce the problem, what kind of error did you get?
Any way I will work in the __init__ file to isolate the ctypes stuff.
All the best
Pietro
> the GUI.
So, now I have seen it at someones computer. It was something about
np.float* in buffer.py. The problem was in yesterday's build of 7.0 for MS
Windows, it is fixed in today's one.
