[GRASS-dev] wxnviz not compiling in GRASS 6.5 svn
I just updated from the CVS, did a make distclean, and compiled.
wxnviz failed to compile with the error below.
Michael
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
========== compile error =============
Errors in:
/Users/cmbarton/grass_dev/grass65_dev/gui/wxpython/nviz
In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fri Jun 25 12:18:45 MST 2010
make: *** [default] Error 1
cmb-MBP:grass65_dev cmbarton$ cd /Users/cmbarton/grass_dev/grass65_dev/gui/wxpython/nviz
cmb-MBP:nviz cmbarton$ make
python setup.py build_ext --swig=/usr/bin/swig --swig-opts=-c++ --build-lib=OBJ.i386-apple-darwin10.4.0 --build-temp=OBJ.i386-apple-darwin10.4.0
running build_ext
building 'grass6_wxnviz’ extension
swigging grass6_wxnviz.i to grass6_wxnviz_wrap.cpp
/usr/bin/swig -python -c++ -o grass6_wxnviz_wrap.cpp grass6_wxnviz.i
gcc-4.2 -fno-strict-aliasing -fno-common -dynamic -DNDEBUG -g -fwrapv -Os -Wall -Wstrict-prototypes -DENABLE_DTRACE -arch i386 -arch ppc -arch x86_64 -pipe -DPACKAGE=“grasslibs” -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXDEBUG
_ -D__WXMAC__ -I/Users/cmbarton/grass_dev/grass65_dev/dist.i386-apple-darwin10.4.0/include -I/Library/Frameworks/GDAL.framework/Versions/1.7/Headers -I/usr/local/lib/wxPython-unicode-2.8.10.1/lib/wx/include/mac-unicode-debug-2.8 -I/usr/local/lib/wxPython-unicode-2.8.10.1/include/wx-2.8 -I/System/Library/Frameworks/OpenGL.framework/Headers -I/System/Library/Frameworks/Python.framework/Versions/2.6/include/python2.6 -c change_view.cpp -o OBJ.i386-apple-darwin10.4.0/change_view.o
cc1plus: warning: command line option “-Wstrict-prototypes” is valid for C/ObjC but not for C++
In file included from /usr/local/lib/wxPython-unicode-2.8.10.1/include/wx-2.8/wx/mac/glcanvas.h:4,
from /usr/local/lib/wxPython-unicode-2.8.10.1/include/wx-2.8/wx/glcanvas.h:60,
from nviz.h:26,
from change_view.cpp:15:
/usr/local/lib/wxPython-unicode-2.8.10.1/include/wx-2.8/wx/mac/carbon/glcanvas.h:49: warning: ‘AGLDrawable’ is deprecated (declared at /System/Library/Frameworks/AGL.framework/Headers/agl.h:48)
/usr/local/lib/wxPython-unicode-2.8.10.1/include/wx-2.8/wx/mac/carbon/glcanvas.h:53: warning: ‘AGLDrawable’ is deprecated (declared at /System/Library/Frameworks/AGL.framework/Headers/agl.h:48)
change_view.cpp: In member function ‘std::vector<double, std::allocator > Nviz::SetViewDefault()’:
change_view.cpp:56: error: cannot convert ‘float*’ to ‘double*’ for argument ‘1’ to ‘int Nviz_get_exag_height(double*, double*, double*)’
change_view.cpp: In member function ‘int Nviz::SetView(float, float, float, float, float)’:
change_view.cpp:81: error: cannot convert ‘nv_data*’ to ‘double’ for argument ‘1’ to ‘int Nviz_set_viewpoint_height(double)’
change_view.cpp:83: error: cannot convert ‘nv_data*’ to ‘double’ for argument ‘1’ to ‘int Nviz_set_viewpoint_position(double, double)’
change_view.cpp:85: error: invalid conversion from ‘nv_data*’ to ‘int’
/Users/cmbarton/grass_dev/grass65_dev/dist.i386-apple-darwin10.4.0/include/grass/nviz.h:134: error: too many arguments to function ‘int Nviz_set_viewpoint_twist(int)’
change_view.cpp:85: error: at this point in file
change_view.cpp:87: error: invalid conversion from ‘nv_data*’ to ‘int’
/Users/cmbarton/grass_dev/grass65_dev/dist.i386-apple-darwin10.4.0/include/grass/nviz.h:133: error: too many arguments to function ‘int Nviz_set_viewpoint_persp(int)’
change_view.cpp:87: error: at this point in file
from nviz.h:26,
In file included from /System/Library/Frameworks/Python.framework/Versions/2.6/include/python2.6/Python.h:8,
from nviz.h:28,
/System/Library/Frameworks/Python.framework/Versions/2.6/include/python2.6/pyconfig.h:894:1: warning: “SIZEOF_LONG” redefined
In file included from /usr/local/lib/wxPython-unicode-2.8.10.1/include/wx-2.8/wx/platform.h:196,
from /usr/local/lib/wxPython-unicode-2.8.10.1/include/wx-2.8/wx/defs.h:21,
from /usr/local/lib/wxPython-unicode-2.8.10.1/include/wx-2.8/wx/wxprec.h:13,
from nviz.h:5,
/usr/local/lib/wxPython-unicode-2.8.10.1/lib/wx/include/mac-unicode-debug-2.8/wx/setup.h:959:1: warning: this is the location of the previous definition
from nviz.h:28,
/System/Library/Frameworks/Python.framework/Versions/2.6/include/python2.6/pyconfig.h:923:1: warning: “SIZEOF_SIZE_T” redefined
from nviz.h:5,
/usr/local/lib/wxPython-unicode-2.8.10.1/lib/wx/include/mac-unicode-debug-2.8/wx/setup.h:968:1: warning: this is the location of the previous definition
from nviz.h:28,
/System/Library/Frameworks/Python.framework/Versions/2.6/include/python2.6/pyconfig.h:944:1: warning: “SIZEOF_VOID_P” redefined
from nviz.h:5,
/usr/local/lib/wxPython-unicode-2.8.10.1/lib/wx/include/mac-unicode-debug-2.8/wx/setup.h:956:1: warning: this is the location of the previous definition
from nviz.h:26,
lipo: can’t open input file: /var/folders/AK/AKpYwDw1EoWI+fFF02nvRk+++TI/-Tmp-//ccZDdadP.out (No such file or directory)
error: command ‘gcc-4.2’ failed with exit status 1
make: *** [OBJ.i386-apple-darwin10.4.0/_grass6_wxnviz.so] Error 1
2010/6/25 Barton Michael <Michael.Barton@asu.edu>:
wxNviz C++ component has been replaced in trunk by wxnviz.py. It will
be also done in devbr6 when ctypes will be backported. Please use till
this time trunk.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
