At 01:12 PM 10/18/96 -0500, you wrote:
Hello--
Does anyone know where I can obtain GRASS plotter drivers for the HP
755CM plotter?
Thanks in advance.
___________________________________________________________________________
_____
Mary F. Chang Phone: (612)
290-5615
Computer Specialist Fax: (612)
290-5256
St. Paul District Corps of Engineers
mfc@ncs.usace.army.mil
190 Fifth Street East __ __
__ __
St. Paul, MN 55101-1638 / / /_ /_/
/ /_
/_/ __/ / /
/_ /_
I've been using Alladin Ghostscript to convert the output from ps.map to rtl
format compatible with the Designjet 650C. I assume the same technique will
work with the 755CM. The web page for Ghostscript can be found at
www.cs.wisc.edu/~ghost/index.html. Source code for Unix machines and
compiled code for DOS and Windows is available at the site. If you are
compiling for a Unix machine, make sure the driver dnj650c is included.
Jim Schmidt
avenues@sonnet.com
