At 01:12 PM 10/18/96 -0500, you wrote:
>Hello--
> Does anyone know where I can obtain GRASS plotter drivers for the HP
>755CM plotter?
>Thanks in advance.
_____
>Mary F. Chang
I've been using Alladin Ghostscript to convert the output from ps.map to rtl
format compatible with the Designjet 650C. I assume the same technique will
work with the 755CM. The web page for Ghostscript can be found at
www.cs.wisc.edu/~ghost/index.html. Source code for Unix machines and
compiled code for DOS and Windows is available at the site. If you are
compiling for a Unix machine, make sure the driver dnj650c is included.
My understanding is that the Hp755CM is shipped ready to print postscript,
as opposed to the 750c, which is not. You should be able to send your file
output from ps.map directly to the plotter. The only file you would need
is the ps.devices text file in $GISBASE/etc/paint/ps.devices, which is used
by ps.select. A sample is included below:
cat ps36x48.300
level: 2
page width: 36
page height: 48
top margin: 0.50
bottom margin: 0.50
left margin: 0.50
right margin: 0.50
resolution: 300
Eric Ohler
USACERL LL-R
ohler@vinny.cecer.army.mil
