GRASS graphics driver can't set color
Hello,
We have problems installing GRASS4.2,4.1 on Red Hat Linux with
XFree3.3.3. Starting x0 monitor within 8 bit X windows
and using d.mon start=x0 we've got the following errors:
Graphics driver [x0] started
Color: can't set color 0
Using X windows with 16 bit or 32 bit colour depths we've got:
X Error of failed request: BadMatch (invalid parameter attributes)
  Major opcode of failed request: 78 (X_CreateColormap)
  Serial number of failed request: 270
  Current serial number in output stream: 271
Do any of you have ideas how to fix it?
We appreciate any help.
With best regards,
Jaro Hofierka
It sounds as if you might be starting X windows as Root. Log in as another
user (not a root user) and then go into X windows and start the monitor.
For some reason X windows will not support 8bit color when logged on as
Root. I am assuming that you have already setup the monitors using via
monitorcap file and set mknod/chmod to the fifo devices. If not it is
really easy to do and if you like I will give you detailed instructions on
how to set them up.
James Harper
-----Original Message-----
From: grass@pandora.cecer.army.mil [mailto:grass@pandora.cecer.army.mil] On
Behalf Of Jaro Hofierka
Sent: Friday, May 21, 1999 11:45 AM
To: grass-list@cecer.army.mil
Subject: GRASS graphics driver can't set color
Hello,
With best regards,
Jaro Hofierka
how to set them up.
James Harper
James,
You are right! Thank you and also all who replied to my request.
Jaro
Hello,
With best regards,
Jaro Hofierka
