This is a mistake on my part. I wrote a version of popen() to allow
multiple popens simultaneously. We should have called it G_popen() and
G_pclose().
A solution is to add -Dpopen=G_popen -Dpclose=G_pclose to the definition
of CFLAGS in the header for gamek4.0 and recompile everything.
|When I run GISGEN or gmake4.0 in the src/libes/gis directory I get the
|following
|rm -f OBJ/popen.o
|cc -O -DGETHOSTNAME_OK -I/grass/src/libes -DUSE_TERMIO -c popen.c
|popen.c: In function 'popen':
|popen.c:15: argument 'cmd' doesn't match prototype
|popen.c:15: argument 'mode' doesn't match prototype
|popen.c: In function 'pclose':
|popen.c:54: warning: assignment from incompatible pointer type
|popen.c:55: " " " " " "
|popen.c:56: " " " " " "
|popen.c:64: warning: passing arg 2 of 'signal' from incompatible pointer
|type
|popen.c:65: "
|popen.c:66: "
|make: *** [OBJ/popen.o] Error 1.
|I'm no C wizard so please politely tell me if I should go home and read up
|on functions first!. I have included the popen.c file below. Thanks for any
|help.
|Alastair J. Small
|asmall2@mach1.wlu.ca
|#include <stdio.h>
|#include <signal.h>
|#define tst(a,b) (*mode == 'r'? (b) : (a))
|#define READ 0
|#define WRITE 1
|static int popen_pid[50];
|FILE *
|popen(cmd,mode)
| char *cmd;
| char *mode;
| int p[2];
| int me, you, pid;
| fflush (stdout);
| fflush (stderr);
| if(pipe(p) < 0)
| return NULL;
| me = tst(p[WRITE], p[READ]);
| you = tst(p[READ], p[WRITE]);
| if((pid = fork()) == 0)
|/* me and you reverse roles in child */
| close(me);
| close(tst(0, 1));
| dup(you);
| close(you);
| execl("/bin/sh", "sh", "-c", cmd, 0);
| _exit(1);
| if(pid == -1)
| return NULL;
| popen_pid[me] = pid;
| close(you);
| return(fdopen(me, mode));
|pclose(ptr)
| FILE *ptr;
| int f, r, (*sighup)(), (*sigint)(), (*sigquit)();
| int status;
| f = fileno(ptr);
| fclose(ptr);
| sigint = signal(SIGINT, SIG_IGN);
| sigquit = signal(SIGQUIT, SIG_IGN);
| sighup = signal(SIGHUP, SIG_IGN);
| while((r = wait(&status)) != popen_pid[f] && r != -1)
| if(r == -1)
| status = -1;
| signal(SIGINT, sigint);
| signal(SIGQUIT, sigquit);
| signal(SIGHUP, sighup);
| return(status);
Michael
