grass to MapInfo and vice-versa
Hello,
  Has anybody had any experience of exchanging vecter data between MapInfo
and Grass - is there a good way of retaining attribute data?
Cheers, Al.
Afaik there is no code around that does the trick. I spent a few hours
trying to make a conversion program, but it's not that easy given
MapInfo's vector data structure (any volunteers?). The best way so far is
to use DXF layers, but this means you'll have to export each attribute in
a separate layer.
Philip Verhagen
P.S. Next time you put a message on the list, it might be a good idea to
add your full name, affiliation and e-mail adress...
      S t i c h t i n g R A A P
    Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
          1018 TV Amsterdam
           THE NETHERLANDS
phone: (31) 20 525 5835
fax: (31) 20 525 5834
e-mail: motte@xs4all.nl
