I had a quick play with this and with a bit of fiddling with the nviz controls I at least managed to get a view of something that could be my 360 degree view.
Than I saved this as a 3d.view file, which looks like this:
4.01
PGM_ID: Nvision-ALPHA!
north: 22.200000
south: 22.100000
east: 105.100000
west: 105.000000
rows: 120
cols: 120
TO_EASTING: 105.041183
TO_NORTHING: 22.117983
TO_HEIGHT: 66.926193
FROM_EASTING: 105.220001
FROM_NORTHING: 21.980000
FROM_HEIGHT: 2024.140015
Z_EXAG: 0.000010
TWIST: 0.000000
FIELD_VIEW: 359.000000
MESH_FREQ: 1
POLY_RES: 1
DOAVG: 0
DISPLAY_TYPE: 2
DOZERO: 1
COLORGRID: 0
SHADING: 1
FRINGE: 0
BG_COL: black
GRID_COL: white
OTHER_COL: red
SURFACEONLY: 0
LIGHTS_ON: 1
LIGHTPOS: 0.296000 -0.344000 0.580000 0.000000
LIGHTCOL: 0.320000 0.592000 0.616000
LIGHTAMBIENT: 0.000000
SHINE: 32.000000
My idea was to take this file as a template and insert my on-the-fly parameters and run nivz like this
nviz elevation=DEM state=statefile
to get the image I want. But as the first thing is that Grass does not like the file it has saved, and throws out lots of error messages, like this
Diagnostic: invalid command name “Nviz_# 4.01_load” – Load procedure for panel # 4.01 may not be defined
Diagnostic: invalid command name “Nviz_PGM_ID: Nvision-ALPHA!_load” – Load procedure for panel PGM_ID: Nvision-ALPHA! may not be defined
Diagnostic: invalid command name “Nviz_north: 22.200000_load” – Load procedure for panel north: 22.200000 may not be defined
Diagnostic: invalid command name “Nviz_south: 22.100000_load” – Load procedure for panel south: 22.100000 may not be defined
Diagnostic: invalid command name “Nviz_east: 105.100000_load” – Load procedure for panel east: 105.100000 may not be defined
Diagnostic: invalid command name “Nviz_west: 105.000000_load” – Load procedure for panel west: 105.000000 may not be defined
Diagnostic: invalid command name “Nviz_rows: 120_load” – Load procedure for panel rows: 120 may not be defined
… (more one for every line)
So NVIZ does not really understand its own file format, yet loading the file from the GUI does not throw out all these error messages, but does not exactly recreate my view either.
Plus: is there a way to make nviz save the view from as an image from the command line? The tiff file I can output via the GUI would be good enough with some post-processing with one of the many image programs…
I have just tested this on XP, with Grass version grass-6.1.cvs-i686-pc-cygwin-13_02_2006, so if anybody thinks this is a version or platform issue, give me a shout.
Ludwig
On 7/2/06, Paul Kelly <paul-grass@stjohnspoint.co.uk > wrote:
Hello Ludwig
On Sun, 2 Jul 2006, Ludwig Max Brinckmann wrote:
Just had a quick look through the old manual pages, so I guess it might do
the trick.
Does anybody have an idea how much porting effort is involved? What is the
reason it is not maintained?
As far I remember the two different versions (cmd and inter - command-line
and interactive) had slightly different functionality but the code was all
mixed up together (i.e. not in separate cmd and inter directories as in other
pre-GRASS 6 modules) and some was shared and some separate. It would be a
lot of work to merge it all cleanly into one definitive set of functionality.
Might not be quite as much work work to get most of the functionality ported.
Bob Covill has added support to NVIZ for setting an explicit viewer
location and centre of view, and for saving this as a 3d.view file in the
GRASS database - I think this works now but I have never tested it.
Before this was added, and if you didn’t have access to a Silicon Graphics
machine to run SG3d on, d.3d was the only choice if you wanted fine
control (by typing in co-ordinates and angles etc; not using the mouse)
over the 3-D view parameters.
FWIW SG3d was quite amazing and years ahead of its time; still has some
features that (as far as I’m aware) aren’t in NVIZ such as projecting a
global Lat-long location onto a sphere.
Paul
