I want to permanently display the grey x/y/z (3D grid) in a 3D view (it actually appears briefly when you apply any movement tool) in the 3D view. I can use a constant surface and a transparency value but it’s not as useful as a grid you can adjust the resolution of.
Is there a way to do it in either 7.3svn or 7.0.5?
On Wed, Nov 16, 2016 at 8:34 AM, Paul Shapley <p.shapley@gmail.com> wrote:
can use a constant surface and a transparency value but it's not as useful
Hi, not sure if I understand you correctly, but if you create a raster
with single value, you can then visualize it in 3D with style coarse
as wire frame.
as wire frame.
